Stable ADC readings
Results 1 to 40 of 91
    Jan 2006
    Istanbul
    Adding to what Jumper said, I also face similar issues.
    Usually, using 7805 or 78L05 may not provide a stable 5V.
    Say it is actually between 4.98V and 5.02V. (approx 5% datasheet statement)
    So, if you are using 10-bit reading there is your problem.
    Eventually, Jumper's suggestion of having a high precision voltage reference is a good idea.
    Another issue :
    Pausing 2ms after each ADCIN command may help.
    And...
    More CAPs.
    A capacitor from the ADC pin to VSS will help smooth things out. Will not make up for a bad power supply though.
    Hi, Sayzer
    I am testing it using a simple voltage divider with two resistors of the same value so that I get a value around 512 (ADC in 10 bit mode).
    That means he works in ratiometric mode and supply changes do not interfere here ...
    so, problem is elsewhere ...
    Jan 2006
    Istanbul
    Hi, Sayzer
    Yes Alain, I missed that.
    Then, may be he should pause ~2ms after each read.
    Also, for example, reading lower voltages and reading higher voltages may behave differently.
    If reading higher voltages are accurate, but lower voltages are not, then there is something else, too.
    Input impedance too high, too short of ADC aquisition time, noisy PSU, unstable PSU, no averaging routine, multiplexed function on the ADC pin, loose/dirty bread board contacts, poor wiring, poor oscillator, poor decoupling, etc... quite a few possibilities...
    Jul 2010
    As mentioned I am decoupling, using averaging, and testing the ratio of two resistors hooked up to the same battery after the regulator.
    Let me draw the schematic and I will post.
    But before that, let me say that I switched from ADCIN to doing a manual ADCON0.1 = 1 reading, and now I get a stable value. So my problem is an erroneous use of the ADCIN command or a problem in the logic of my routine.
    BEFORE:
    DEFINE ADC_BITS 10 ' Set number of bits in result (8, 10 or 12)
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    WSum = 0
    Pause 100
    For i = 0 to 49
    ADCIn PinProbe, W0
    Pause 10
    WSum = WSum + W0
    Next i
    W0 = WSum / 50
    NOW:
    Pauseus 50 'Stabilize
    ADCON0.1 = 1  'start the ADC
    WHILE ADCON0.1 : WEND
    W0.HighByte = ADRESH
    W0.LowByte = ADRESL
    It works, now the reading stays fixed and it is much faster. (I even didn't have to do any averaging)
    What about reinitialising your Wsum value to 0 @ each 50 samples batch ??? don't you run this loop in another continuous loop ... ??? " par hasard " ...
    BTW " PinProbe " is the alias for which pin ???
