Stable ADC readings
Results 1 to 40 of 91
    Aug 2011
    Default Re: Stable ADC readings
    I think it is more reliable to use Kline to access to all functions (i am going to try to use these adresses Kline functions)
    i have a code but i have to work on it (Kline access based) .i will give a part of it in a new post to hope that someone can help us about it .
    Because my FIS display base code is the same than Golfop...(take on a yahoo group FREELY and freely redistriable but now it is too expensive to buy it---lot of work on it) .
    For try it , we have to use a little program to send caracters between DB25// and K-line .(see logs) LOGS.zip
    Aug 2011
    EDIT :
    See logs for what reacts FIS with sent caracters ... Attachment 6112
    LineK schematics , but we need a program to send values to see how reacts car radio LineK wire ...
    Name:  K-line E1_E2 PIC 16F877A.JPG
    code :
    data(data line),clk(clock)
    suma=0
    dat=126
    Shiftout data, clk, 5,[dat]
    suma=suma ^ dat
    Rem High data
    dat=237
    Shiftout dato, clk, 5,[dat]
    suma=suma ^ dat
    Rem Low data
    dat=15
    suma=suma ^ dat
    Rem High data
    It is for DATA Line send (ENA/CLOCK/DATA)
    For cont=0 To 15
    tmp=msg[cont]
    Rem dat=255 - tmp
    dat= ~ tmp
    suma=suma ^ dat
    Rem Low data
    Next cont
    'Somme de controle (sum)
    dat=suma + 1
    Rem Low data
    High ena
    posy=255
    GoSub display
    FisDw:
    Low ena
    suma=0
    dat=169
    sum=sum ^ dat
    know 255-longitude del msg
    dat=241
    sum=sum ^ dat
    It is for example ,but it is a little part of sent values .
    Thanks in advance to ameliorate or given answers .
