Stable ADC readings
Results 1 to 40 of 91
    Default Re: Stable ADC readings
    Good news! The code itself should be fast enough, I guess the radio need some time to process it, and sure enough, it's not on his high priority task.
    Post your code here, I'll check if I see something weird.
    PS: when you post a code here use the code tags, this way it appear in a code box, and we don't miss the outdent format. It is really simple to do.
    [code]
    paste your code here
    [/code]
    Aug 2011
    Steeve ,
    do you know where is the values for other functions like up/down/valid (press 2 or 3 seconds on function button) / EQ/Display ?
    I have all general functions under 100kohms .
    it is for DEH-6900IP Pioneer .
    Thanks.
    Nope, sorry. Their service manual makes no mention of it, and the only thing I found was something like,
    http://www.jvde.net/pioneer_wired_re...red_remote.htm
    Even the original wired remote from Pioneer make no mention of this specific feature
    http://www.pioneerelectronics.com/PU...ntrols/CD-MR70
    Aug 2011
    Do the diode zener serve to fix no Function if i have no +12V on input regulator ?
    Because when i put off +12V , i have a loop function (again and again.....)
    You'll also need to disconect the GND line then. When you apply power to your PIC, the Hi-Z is granted on the output port, while not when you disconnect the power...
