Stable ADC readings
Results 1 to 40 of 91
    Default Re: Stable ADC readings
    I Bet there are no pull ups on port A inputs.
    Aug 2011
    Guadalajara, México
    mazoul72, I'm really new to picbasic, but I note in your schematic that you don't have pull-up resistor, so please try something like this:
    Also, try to code something like the below example, if you rotate the bits of your ADC reading, you can leave only the 2 most significating bits, this way, you can know the exact button pressed (of course you must calculate correctly the resistors values):
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    ADVal var byte
    Switch var byte
    Principal:
    adcin 3,adval
    switch = (adval >> 6) 'Shift for 2 MSB for values 0 to 3 representing each button
    SELECT CASE switch
    CASE 0
    'Put your code here
    gpio=0
    CASE 1
    'Put your code here
    high gpio.0
    CASE 2
    'Put your code here
    high gpio.1
    CASE 3
    'Put your code here
    high gpio.2
    END SELECT
    goto principal
