How to use an Interrupt to drive a menu on 16f88
Results 1 to 8 of 8
    Feb 2005
    Bellevue
    Ahhh! OK! I thought interrupts were things you could assign to any pin, that is all. I was looking to closely at this to notice that RB0 had an assigned function 'INT'..
    I have a proto board made up that runs rb4 and rb5 off to a post for easily attaching pins to - the reason I wanted to use RB4.. I can tie off to RB0 but it is a little soldering now, that's all. Btw, RB0 is pin #6 on the F88. Pin 4 is MCLR.
    One other thing - 'enable pull up resistor' - do I need to tie a 1K ohm resistor from VDD to the pin also, or is this a software switch?
    Tom
    Feb 2005
    Essex, UK
    Ah, now i have learnt something !!
    Steve, so in the example code i have posted, what part needs to be changed to reflect the different PORT for the Inturrupt.
    Cheers,
    Feb 2005
    Bellevue
    Question
    So.... Is there some way to listen for interrups on RB4? Or is the chip designed to have interrupts come in vai RB0?
    Tom
  1. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  2. 16f88 interrupt
    By tur_bot in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 11:35
  3. 16F88 Interrupt
    By sskeet in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 15:51
  4. Interrupt Menu System Example and Help Needed
    Last Post: - 1st April 2005, 17:05
    Last Post: - 6th March 2005, 01:07
