I'm still learning myself but i hope this works for your need or is a good pointer. This i have test and works on my development board. Each time you push the switch on the Interupt pin, the LEDs on PORTB light in sequence as you push the switch.
' I/O definition
TRISB = %10000001   ' Set PORTB (0)INPUT (1-5)OUTPUTS
' Variable Definition
Switch              VAR PORTB.0
PushHowManyTimes    VAR Byte
' register and interrupt definition
CMCON = 7          ' Disable analog comparator on PORTA... not needed as now
OPTION_REG=0       ' enable pull-up resistor on PORTb
                   ' Interrupt on falling edge of RB0
INTCON = %10010000 ' Enable RB0 interrupt
On Interrupt Goto ProcedureSwitcher
' Variable initialisation
PORTB=0             ' Reset all outputs on PORTB
PushHowManyTimes=0
'Main Procedure
MainProcedure:
      Select Case PushHowManyTimes
             case 1
                  Gosub Routine_1
             Case 2
                  Gosub Routine_2
             Case 3
                  Gosub Routine_3
             Case 4
                  Gosub Routine_4
             Case 5
                  Gosub Routine_5
             End Select
Goto Mainprocedure
Routine_1:
    High 1
Routine_2:
    High 2
Routine_3:
    High 3
Routine_4:
    High 4
Routine_5:
    High 5
' Interrupt handler stuff here
Disable                                     ' Disable interrupts in handler
ProcedureSwitcher:
    PushHowManytimes=PushHowManytimes+1     ' Changing task
    If PushHowManytimes=6 Then PushHowManytimes=1
Here:
    While SWITCH = 0                        ' waiting until
    wend                                    ' push-button is release
    pause 100                               ' debounce time
    If switch=0 then here
    INTCON.1=0                              ' reset RB0 interrupt flag
Resume                                      ' Return to main program
Enable                                      ' Enable interrupts after
                                            ' handler
As i say, still learning myself, but willing to help where i can !!
