question regarding an external AD converter
Results 1 to 3 of 3
    dtoohey's Avatar
    dtoohey Guest
    Default question regarding an external AD converter
    I'm trying to interface a 12-bit AD converter(Gyropoint ASIC) with a PIC16F876, but I'm stuck.
    The instructions for the AD converter call for a 4Mhz clock. Thinking I could use my PIC and its 4Mhz crystal to provide the clocking, I connected the PIC OSC2 pin to the MSTR_CLK pin of the AD converter.. Is this okay? I suspect it is not since i'm getting nothing but a "0" reading when I display the data. While it may be that other portions of my code are causing the problems, I figure it's most likely this clock issue.... I'm pretty new at this stuff, so any help will be most appreciated.
    Damian
    sonic's Avatar
    sonic Guest
    Default Timing Diagrams
    HI,D!
    First of all, find a PDF file for your ADC and read it carefully.
    Pay attention on timing diagrams!!!
    Picture u have sent I suppose has wrong connection between PIC and ADC - Din (ADC) goes to Dout (MCU) and Din (MCU) goes to Dout (ADC).
    dtoohey's Avatar
    dtoohey Guest
    Hi Sonic, thanks for the reply.
    turns out i had an incorrect mode set for my shiftout statement. everything seems to work fine now. Looks like the clock pin for the ADC can be connected to the OSC2 pin of the PIC after all.
  1. A question on defining the external oscillator
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2009, 14:31
  2. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 00:40
  3. PIC AD + Vref- using external IC
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 19th June 2007, 02:05
  4. 16F88 - AD converter module always "ON"
    Last Post: - 18th September 2006, 12:11
  5. external A/d converter
    By Knightlord in forum mel PIC BASIC Pro
    Last Post: - 24th September 2004, 23:53
