If I am using this statement, PWM portb.7, 127,100.
Is there a way to stop it before it finishes?
Thanks, Don
 A PWM question
 A PWM question
Thanks, Don
		Yes, remove power from the PIC
Once you start a pwm software based pwm, it will complete before it moves on.
http://www.scalerobotics.com
		Objection ...
an asm interrupt can stop it ... but with an external action ! ( also possible with a timer ... but what the real use ? )
		Timmer interrupt, HPWM would work. A huge "safety Break" button in serie is never a bad idea in case the driver goes nuts. Current read from the motor, feed into the pic and all plah plah is also a nice extra... Even better if you keep track of every "events" around...
- Objection acceptéeOriginally Posted by Acetronics
Objection ...
- Merci votre honneur
