PAUSE statement
Results 1 to 3 of 3
Thread: PAUSE statement
    Mar 2008
    Default PAUSE statement
    Is there a minimum time value for the PAUSE statement? I know you have to set the OSC speed but the PAUSE values are way off.
    Mar 2008
    PAUSE 100 in my code is about 100 seconds PIC18F2450
    Aug 2010
    Maryland, USA
    I think the minimum for PAUSE is 1mS, shorter pauses should use PAUSEUS.
    There are up to 3 things to verify for the pause to work correctly.
    DEFINE OSC - Used to tell PBP what speed to use for calculating PAUSE,SERIN/OUT, and so forth
    OSCCON - Depending on the PIC used, this is to set the PIC to the desired speed
    In the config settings, internal or external OSC.
    If using INTERNAL OSC, verify default speed.
    -Bert
