USB Interface using PIC
Results 1 to 22 of 22
    DOes any of you have a schematic of how to connect the PIC18F2455 to the usb?
    And does somebody have a example prog that is realy for pbp FOR A pic18f2455
    OXIMBIT's Avatar
    OXIMBIT Guest
    Have you tried looking in the manual?
    Yes i tried i try to compile the example code:
    USBCDC but can't get it work, i want to use a PIC2455.
    This is the PBP code:
    ' USB sample program for PIC18F4550 CDC serial port emulation
    ' Compilation of this program requires that specific support files be
    ' available in the source directory. You may also need to modify the
    ' file USBDESC.ASM so that the proper descriptor files are included. For
    ' detailed information, see the file PBP\USB18\USB.TXT.
    buffer Var Byte[16]
    cnt Var Byte
    LED Var PORTB.0
    Define OSC 48
    USBInit
    Low LED ' LED off
    ' Wait for USB input
    idleloop:
    USBService ' Must service USB regularly
    cnt = 16 ' Specify input buffer size
    USBIn 3, buffer, cnt, idleloop
    ' Message received
    Toggle LED
    buffer[0] = "H"
    buffer[1] = "e"
    buffer[2] = "l"
    buffer[3] = "l"
    buffer[4] = "o"
    buffer[5] = " "
    buffer[6] = "W"
    buffer[7] = "o"
    buffer[8] = "r"
    buffer[9] = "l"
    buffer[10] = "d"
    buffer[11] = 13
    buffer[12] = 10
    buffer[13] = 0
    outloop:
    USBOut 3, buffer, 14, outloop
    Goto idleloop ' Wait for next buffer
    Getting further, the PBP goes compiling now only thany he asked for the MPASM compiler so i installed this compiler made the path settings.
    Then he start the MPASM only it gives the error.
    Error in parameter "18F4550"
    Another step closer,
    Windows detect a USB device but an unknown, and installing the "PBPCDC"
    drivers have no effect. sombody?
    Windows detects the USB PIC now,
    only now i need a working description.asm file. Because the standard description (demo pbp files) don't set every setting in windows.
    Like manufacture, product and more.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 12:00
  3. Replies: 15
    Last Post: - 30th October 2007, 19:25
  4. USB bluetooth interface to PIC
    By naidab in forum Bluetooth
    Last Post: - 17th March 2007, 22:37
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
