Sounds like what exactly after. Two questions then, what Compiler are you using and can you send these demos to me on email? I've sent you a PM with my email address.
Many thanks,
Many thanks,
DOes any of you have a schematic of how to connect the PIC18F2455 to the usb?
And does somebody have a example prog that is realy for pbp FOR A pic18f2455
Yes i tried i try to compile the example code:
USBCDC but can't get it work, i want to use a PIC2455.
This is the PBP code:
' USB sample program for PIC18F4550 CDC serial port emulation
' Compilation of this program requires that specific support files be
' available in the source directory. You may also need to modify the
' file USBDESC.ASM so that the proper descriptor files are included. For
' detailed information, see the file PBP\USB18\USB.TXT.
buffer Var Byte[16]
cnt Var Byte
LED Var PORTB.0
Define OSC 48
USBInit
Low LED ' LED off
' Wait for USB input
idleloop:
USBService ' Must service USB regularly
cnt = 16 ' Specify input buffer size
USBIn 3, buffer, cnt, idleloop
' Message received
Toggle LED
buffer[0] = "H"
buffer[1] = "e"
buffer[2] = "l"
buffer[3] = "l"
buffer[4] = "o"
buffer[5] = " "
buffer[6] = "W"
buffer[7] = "o"
buffer[8] = "r"
buffer[9] = "l"
buffer[10] = "d"
buffer[11] = 13
buffer[12] = 10
buffer[13] = 0
outloop:
USBOut 3, buffer, 14, outloop
Goto idleloop ' Wait for next buffer
Getting further, the PBP goes compiling now only thany he asked for the MPASM compiler so i installed this compiler made the path settings.
Then he start the MPASM only it gives the error.
Error in parameter "18F4550"
