USB Interface using PIC
Results 1 to 22 of 22
    OXIMBIT's Avatar
    OXIMBIT Guest
    The PIC18F4550 has a USB2 interface, it's brilliant!! I can use it behave like a Mouse or use the USB interface as virtual serial port. There are other devices in the USB family as well.
    Do you have any example of code, that this pic is show as a virtual com in windows?
    OXIMBIT's Avatar
    OXIMBIT Guest
    Heres some code, It should all convert to Pbpro really easly
    ' General purpose USB CDC test program.
    ' Transmits data from several different buffers.
    ' And displays the contents of the USBIN buffer on the LCD
    ' Uses transmit and receive detection using the CARRY flag (STATUS.0)
    ' Communicate via the serial terminal set to the com port that the USB connects too.
    	OPTIMISER_LEVEL = 2								' Enable the optimiser at level 2
    	Device = 18F4550								' Choose a device with on-board full speed USB
        XTAL = 48										' Set the oscillator speed to 48MHz (using a 20MHz crystal)
        REMINDERS = OFF									' Disable all reminders
        LCD_DTPIN = PORTD.4								' LCD data port attached to PORTD
    	LCD_RSPIN = PORTE.0								' LCD RS pin attached to PORTE.0
    	LCD_ENPIN = PORTE.1								' LCD EN pin attached to PORTE.1
    	LCD_INTERFACE = 4								' 4-bit Interface
    	LCD_LINES = 2									' 2 line LCD
    	LCD_TYPE = ALPHANUMERIC							' Use an Hitachi alphanumeric LCD
        USB_DESCRIPTOR = "CDCDESC.INC"					' Point to the CDC DESCRIPTOR file (located in the INC\USB_18 folder)
        Dim PP0 As Byte SYSTEM							' USBPOLL status return
        Dim VAR1 As Word								' General purpose variable
        Dim ARRAY1[20] As Byte 							' Used to hold some output characters
       	Dim OUT_BUFFER As String * 20					' Used to hold some output characters
        Dim IN_BUFFER As String * 20					' Used to hold some input characters
        Symbol CARRY_FLAG = STATUS.0					' High if microcontroller does not have control over the DP buffer
        Symbol TRNIF = UIR.3							' Low if USB Busy
    ' The main program loop starts here
        DelayMS 200											' Wait for things to stabilise
        ALL_DIGITAL = True									' Set PORTA and PORTD to digital mode
        Clear												' Clear all RAM before we start
        Cls													' Clear the LCD
        Repeat												' \
        	USBPoll											'   Wait for the USB interface to become attached
        Until PP0 = %00000110								' /
        StrN ARRAY1 = " ARRAY BUFFER\n\r"    				' Fill the array with NULL terminated characters
        OUT_BUFFER = " STRING BUFFER\n\r"                   ' Fill the string with NULL terminated characters
    	VAR1 = 0     										' Reset the counting variable
    	While 1 = 1											' Create an infinite loop
            Repeat											' Wait for USB input
            	USBIn 3, IN_BUFFER, Auto					' Poll the USB and Receive some data from endpoint 3
            Until CARRY_FLAG = 0							' Keep looking until data is able to be received
            Print At 1,1,"USB BUFFER"
            Print At 2,1,IN_BUFFER                     		' Display the contents of the USB buffer on line 2 of the LCD
            Clear IN_BUFFER                            		' Then clear the buffer for the next time
            __USBOUT_BUFFER = " USB BUFFER\n\r" 			' Place characters directly into the USB TX buffer string
    ' Transmit from the USB's internal TX buffer String. NULL terminated.
            Repeat
    			USBOut 3, __USBOUT_BUFFER, Auto 			' Poll the USB and Transmit the buffer from endpoint 3
        	Until CARRY_FLAG = 0							' Keep trying if the microcontroller does not have control over the buffer
            Repeat : Until TRNIF = 1						' Wait for completion before transmitting anything else
    ' Transmit from a NULL terminated array
            Repeat
    			USBOut 3, ARRAY1, Auto 						' Poll the USB and Transmit the buffer from endpoint 3
    ' Transmit from a NULL terminated String
            Repeat
    			USBOut 3, OUT_BUFFER, Auto 					' Poll the USB and Transmit the buffer from endpoint 3
    ' Transmit from a NULL terminated code memory String
            Repeat
    			USBOut 3, TEXT_STRING, Auto 				' Poll the USB and Transmit the buffer from endpoint 3
    ' Transmit a NULL terminated quoted string of characters
            Repeat
    			USBOut 3, " QUOTED STRING\n\r", Auto 		' Poll the USB and Transmit the buffer from endpoint 3
    ' Transmit 12 characters from a code memory String
            Repeat
            	USBOut 3, TEXT_STRING, 12 					' Poll the USB and Transmit only 12 characters of the buffer from endpoint 3
            __USBOUT_BUFFER = "\n\rVAR1 = " + Str$(Dec,VAR1) + "\n\r"  ' Convert VAR1 into a string
    		Repeat
            Inc VAR1
        Wend												' Go wait for the next buffer input
    TEXT_STRING: CData " CODE MEMORY BUFFER\n\r",0
    oke thanx for the info i give it a try only i'm suppriced about how windows will detect this device
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 12:00
  3. Replies: 15
    Last Post: - 30th October 2007, 19:25
  4. USB bluetooth interface to PIC
    By naidab in forum Bluetooth
    Last Post: - 17th March 2007, 22:37
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
