Originally Posted by
Bobw55
Here is the latest code I have been trying to build.
And this is the error message I receive :
3 304 Syntax error: Expected "program" but "module" found TEST.mbas
'*Header****************************************** ************/
module TEST
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
unsigned char ch; //
unsigned int adc_rd; // Declare variables
char *text; //
long tlong; //
void main() {
INTCON = 0; // All interrupts disabled
ANSEL = 0x04; // Pin RA2 is configured as an analog input
TRISA = 0x04;
ANSELH = 0; // Rest of pins are configured as digital
Lcd_Init(); // LCD display initialization
Lcd_Cmd(_LCD_CURSOR_OFF); // LCD command (cursor off)
Lcd_Cmd(_LCD_CLEAR); // LCD command (clear LCD)
text = "mikroElektronika"; // Define the first message
Lcd_Out(1,1,text); // Write the first message in the first line
text = "LCD example"; // Define the second message
Lcd_Out(2,1,text); // Define the first message
ADCON1 = 0x82; // A/D voltage reference is VCC
TRISA = 0xFF; // All port A pins are configured as inputs
Delay_ms(2000);
text = "voltage:"; // Define the third message
while (1) {
adc_rd = ADC_Read(2); // A/D conversion. Pin RA2 is an input.
Lcd_Out(2,1,text); // Write result in the second line
tlong = (long)adc_rd * 5000; // Convert the result in millivolts
tlong = tlong / 1023; // 0..1023 -> 0-5000mV
ch = tlong / 1000; // Extract volts (thousands of millivolts)
// from result
Lcd_Chr(2,9,48+ch); // Write result in ASCII format
Lcd_Chr_CP('.');
ch = (tlong / 100) % 10; // Extract hundreds of millivolts
Lcd_Chr_CP(48+ch); // Write result in ASCII format
ch = (tlong / 10) % 10; // Extract tens of millivolts
ch = tlong % 10; // Extract digits for millivolts
Lcd_Chr_CP('V');
Delay_ms(1);
Bob
