Clock and Dual Termometer
Results 1 to 25 of 25
    Dec 2008
    Ploiesti, ROMANIA
    Default Clock and Dual Termometer
    Hi everyone !
    I try to build for my use , in home, one clock with dual termometer, using 16F628A, 2x16 LCD and 2 x DS18B20. I wrote the code, but... at every minute I have a few seconds more...I don't have a clue where it's the mistake. Can help me, please ? Thanks in advance !
    @ DEVICE pic16F628A, XT_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF
    TRISA= %11111000                       ' RA0..3=Outputs RA4=Input
    TRISB= %00001111 			    ' RB0..RB2=Inputs, RB3..RB7=Outputs
    CMCON=7                                     ' Disable comparators
    OPTION_REG=%00000111
    DEFINE LCD_DREG PORTB               ' LCD on port B
    DEFINE LCD_DBIT 4                        ' Data bits B4..B7
    DEFINE LCD_RSREG PORTA            ' RS on PORTA
    DEFINE LCD_RSBIT 1                     ' RS on A1
    DEFINE LCD_EREG PORTA              ' E on PORTA
    DEFINE LCD_EBIT 0                       ' E on A0
    DEFINE LCD_BITS 4                      ' LCD 4 bit mode
    DEFINE LCD_LINES 2                     ' 2 line LCD display
    TempC           var     word
    Float           var     word
    Sign		    var	bit		   ' +/- sign
    DQ		    var     PORTA.4	   ' One-wire data pin
    TempC2          var     word
    Float2          var     word
    Sign2		    var	BIT		   ' +/- sign
    DQ2		    var     PORTA.3	   ' One-wire data pin
    Delay           var     byte
    Mode            var     byte
    semn		    var     word
    semn2           var     word
    DS18B20_1_12bit CON %01111111 	   ; 750ms,   0.0625°C  (default)
    DS18B20_2_12bit CON %01111111          ; 750ms,   0.0625°C  (default)
    Ticks		var	byte 	               ; Tick count (61 ticks=1 sec)
    Hour		var	byte 			   ; Hour variable
    Minute	var	byte 	               ; Minute variable
    Second	var	byte   	         ; Second variable
    ZIUA        var   byte
    LUNA        var   byte
    Disp		var	byte 	               ; Disp=1 to update display
    PAUSE 500 					   ; Wait 0.5sec for LCD to initialize
    Hour=0 : Minute=0 : Second=0
    Ticks=0  : ZIUA=01 : LUNA=01
    OPTION_REG=$05 				   ; Set prescaler
    ON INTERRUPT GOTO ISR			   ; ISR routine
    INTCON=$A0 					   ; Enable TMR
    LCDOUT $FE, 1 			         ; Clear LCD
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_1_12bit]
     OWOut DQ, 1, [$CC, $48]
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [TempC.byte0, TempC.byte1]
     Pause 50
    ' Init Sensor 2
     OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_2_12bit]
     OWOut DQ2, 1, [$CC, $48]
     OWOut DQ2, 1, [$CC, $B8]
     OWOut DQ2, 1, [$CC, $BE]
     Pause 50
     OWIn DQ2, 2, [TempC2.byte0, TempC2.byte1]
     Pause 50
    LOOP:
    If PORTB.0=0 then                       ' Mode switch preSeconded
      	Pause 50                          ' Debounce
    	LcdOut $FE, 1
     	LcdOut $FE, $C0, "         SETTING"    ' Show that coMinuteand is accepted
    	PAUSE 500
     	LcdOut $FE, 1
    If PORTB.0=0 then Loop                  ' Wait until button is released
      Mode=Mode+1                           ' Increment mode
    If Mode=1 then                          ' SET HOUR
    LcdOut $FE, $80, dec2 Hour
    LcdOut $FE, $C0, "HOUR     SETTING"
    	if portb.1=0 then
          Hour=Hour+1
            IF Hour=24 then
              Hour=0
          Gosub Debounce
    	if portb.2=0 then
            IF Hour = 0 then
              Hour=24
          Hour=Hour-1
          Gosub Debounce
    EndIf
    If Mode=2 then                          ' SET MINUTES
    LcdOut $FE, $80, dec2 Hour,":",dec2 Minute
    LcdOut $FE, $C0, "MINUTES  SETTING"
    	if portb.1=0 then
          Second=0
          Minute=Minute+1
            IF Minute=60 THEN
              Minute=0
          Gosub Debounce
    	if portb.2=0 then
          Second=0
            IF Minute =<0 THEN
              Minute=60
          Minute=Minute-1
    	Gosub Debounce
    EndIf
    If Mode=3 then                          ' SET DAY
    LcdOut $FE, $80, dec2 Hour,":",dec2 Minute,":",dec2 Second,"   ",DEC2 ZIUA,"/"
    LcdOut $FE, $C0, "DAY      SETTING"
    	if portb.1=0 then
          ziua=ziua+1
                IF LUNA=2 THEN
                      IF ZIUA > 28 THEN
                      ZIUA=1
                IF LUNA=4 OR LUNA=6 OR LUNA=9 OR LUNA=11 THEN
                      IF ZIUA > 30 THEN ZIUA=1
                      IF ZIUA > 31 THEN ZIUA=1
          Gosub Debounce
    	if portb.2=0 then
          ZIUA=ZIUA-1
                IF ZIUA = 0 THEN ZIUA=31
          Gosub Debounce
    EndIf
    If Mode=4 then                           ' SET MONTH
    LcdOut $FE, $80, dec2 Hour,":",dec2 Minute,":",dec2 Second,"   ",DEC2 ZIUA,"/",DEC2 LUNA
    LcdOut $FE, $C0, "MONTH    SETTING"
    	if portb.1=0 then
          luna=luna+1
                if luna>12 then
                luna=1
          Gosub Debounce
    	if portb.2=0 then
          luna=luna-1
                if luna<1 then
                luna=12
          Gosub Debounce
    EndIf
    If Mode > 4 then
    	LCDOUT $FE, $C0, "END      SETTING"
    	PAUSE 1000
        LCDOUT $FE, 1, $FE, $0C
    	mode=0
    EndIf
    If Mode > 0 then Loop
    IF Disp=1 THEN
    LcdOut $FE, $80, DEC2 Hour, ":",DEC2 Minute, ":",DEC2 Second,"   ",DEC2 ZIUA,"/",DEC2 LUNA
    LCDOUT $FE, $C0, semn,DEC ABS TempC/100,".", DEC1 ABS TempC/10, 223,"C ", $FE, $C0 + 9, semn2,DEC ABS TempC2/100,".", DEC1 ABS TempC2/10, 223,"C   "
    Disp=0
    GOTO LOOP
    DISABLE
    ISR:
    Ticks=Ticks + 1
    IF Ticks < 61 THEN NoUpdate
    Ticks=0
    Second=Second + 1 		   ; Update second
    IF Second=60 THEN
    Second=0
    Minute=Minute + 1 		   ; Update Minute
    IF Minute=60 THEN
    Minute=0
    Hour=Hour + 1 			   ; Update Hour
    IF Hour=24 THEN
    Hour=0
    ZIUA=ZIUA+1
              IF LUNA=2 THEN
                   IF ZIUA > 28 THEN
                        ZIUA=1
                        LUNA=3
                   IF ZIUA > 30 THEN
                        ZIUA=1
                        LUNA=LUNA+1
              IF LUNA=1 OR LUNA=3 OR LUNA=5 OR LUNA=7 OR LUNA=8 OR LUNA=10  THEN
                   IF ZIUA > 31 THEN
                        ZIUA=1
                        LUNA=LUNA+1
      	    IF LUNA=12 THEN
                   IF ZIUA > 31 THEN
                        ZIUA=1
                        LUNA=1
    Disp=1 				   ; Set to update display
    Gosub Read_temp
    NoUpdate:
    INTCON.2=0 				   ; Re-enable TMR0 interrupts
    Resume
    ENABLE 				   ; Re-enable interrupts
    ;Subrutine
    Debounce:
    FOR Delay=1 To 200
    Pause 1 				   ; Delay 1ms inside a loop. This way,
    NEXT Delay 				   ; timer interrupts are not stopped
    Disp=1 				   ; Set display flag to 1
    Read_Temp:
        OWOut DQ, 1, [$CC, $44]
        Sign = TempC.15
        TempC = ABS(TempC)
        TempC = ((TempC >> 4)*100) + ((TempC & $F)*100 >> 4)
        IF Sign THEN TempC = -TempC
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        OWOut DQ2, 1, [$CC, $44]
        Sign2 = TempC2.15
        TempC2 = ABS(TempC2)
        TempC2 = ((TempC2 >> 4)*100) + ((TempC2 & $F)*100 >> 4)
        IF Sign2 THEN TempC2 = -TempC2
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    END 					   ; End of program
    That is one of the problems with ON INTERRUPT. It does not interrupt until the main code gets a break. If, for example the code is in a PAUSE when the interrupt happens, the code will not go to the ISR until the PAUSE is complete.
    You will need to use ASM interrupts or DT's instant interrupts.
    Hi, Fratello
    Even using ON INTERRUPT ... you shouldn't have such a time error ... ( just display " not so regularly " the correct HH:MM:SS )
    but maybe you could write the shortest as possible interrupt stubb, not jumping from here to there ...
    the problem looks to be your interrupt stubb is longer than the time between two Timer interrupts. ( 1/61 s ? - from your ISR calculations )
    Dec 2008
    Ploiesti, ROMANIA
    Ok, I think that my previous code it's wrong in his essence...so...
    I try another two version, based on codes from : Paul R. Borgmeier, PhD (see EZCLOCK1) and Mr.Bruce (see RENTRON.COM). Still not good precision ... Any ideeas ?
    @ DEVICE pic16F628A, XT_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF     ' for PBP 2.4
    INCLUDE "AllDigital.pbp"
    INTCON=0
    HzTimer         Var     Word
    HH              Var     Byte
    MM              Var     Byte
    SS              Var     Byte
    ZIUA            VAR     BYTE
    LUNA            VAR     BYTE
    X       	    Var     Byte
    col             Var     Bit
    TempC           Var     Word
    Float           Var     Word
    Sign		    Var	BIT		   ' +/- sign
    DQ		    Var     PORTA.4	   ' One-wire data pin
    TempC2          Var     Word
    Float2          Var     Word
    Sign2		    Var	BIT		   ' +/- sign
    DQ2		    Var     PORTA.3	   ' One-wire data pin
    Delay           var     byte
    Mode            VAR     BYTE
    semn		    var word
    semn2           var word
    HzTimer = $7A12
    HH=00 : MM=00 : SS=00 : ZIUA=01 : LUNA=01 : col=0  : Mode=0
    Pause 500
    LCDOUT $FE, 1, $FE, $0C                 ' Clear display, cursor off
    Pause 100
    ' Init Sensor 1
     OWOut DQ, 1, [$CC, $48]       	    ' Start temperature conversion
     Pause 50
     Pause 50
    ' Init Sensor 2
     OWOut DQ2, 1, [$CC, $48]       	    ' Start temperature conversion
     Pause 50
     Pause 50
    OPTION_REG.7=1
    TMR0=0
    INTCON.2=0
    Pause 500
    Pause 250
    LCDOUT $FE, $80,  "  TERMO-CLOCK   "
    LcdOut $FE, $C0,  "By NICULESCU DAN"
    PAUSE 3000
    MainLoop:
     If PORTB.0=0 then                      ' Mode switch pressed
      Pause 50                              ' Debounce
    LcdOut $FE, 1
     LcdOut $FE, $C0, "         SETTING"    ' Show that command is accepted
    PAUSE 500
     LcdOut $FE, 1
    If PORTB.0=0 then MainLoop              ' Wait until button is released
    LcdOut $FE, $80, dec2 HH
    	if portb.1=0 then
          HH=HH+1
            IF HH=24 then
              HH=0
          Gosub Debounce
    	if portb.2=0 then
            IF HH = 0 then
              HH=24
          HH=HH-1
          Gosub Debounce
    EndIf
    LcdOut $FE, $80, dec2 HH,":",dec2 MM
    	if portb.1=0 then
          SS=0
          MM=MM+1
            IF MM=60 THEN
              MM=0
          Gosub Debounce
    	if portb.2=0 then
          SS=0
            IF MM =<0 THEN
              MM=60
          MM=MM-1
    	Gosub Debounce
    EndIf
    LcdOut $FE, $80, dec2 HH,":",dec2 MM,":",dec2 ss,"   ",DEC2 ZIUA,"/"
    	if portb.1=0 then
          ziua=ziua+1
                IF LUNA=2 THEN
                      IF ZIUA > 28 THEN
                      ZIUA=1
          Gosub Debounce
    	if portb.2=0 then
          ZIUA=ZIUA-1
          Gosub Debounce
    EndIf
    LcdOut $FE, $80, dec2 HH,":",dec2 MM,":",dec2 ss,"   ",DEC2 ZIUA,"/",DEC2 LUNA
    	if portb.1=0 then
          luna=luna+1
                if luna>12 then
                luna=1
          Gosub Debounce
    	if portb.2=0 then
          luna=luna-1
                if luna<1 then
                luna=12
          Gosub Debounce
    EndIf
    If Mode > 4 then
    	PAUSE 1000
    	mode=0
    EndIf
    If Mode > 0 then Mainloop
    Main :
    ClockLoop : IF INTCON.2=0 THEN ClockLoop
    INTCON.2=0
    if portb.0=0 then Gosub MainLoop
    HzTimer = HzTimer - $1000  'decrement timer
    IF HzTimer<$1000  THEN
        IF Col=1 THEN 'update time'
            SS=SS+1
            IF SS=60 THEN
                SS=0
                MM=MM+1
                IF MM=60 THEN
                    MM=0
                    HH=HH+1
                    IF HH=24 THEN
                        HH=0
                        ZIUA=ZIUA+1
                             IF LUNA=2 THEN
                                 IF ZIUA > 28 THEN
                                 ZIUA=1
                                 LUNA=3
                                    IF ZIUA > 30 THEN
                                    ZIUA=1
                                    LUNA=LUNA+1
                                    IF ZIUA > 31 THEN
                                    ZIUA=1
                                    LUNA=LUNA+1
    				 IF LUNA=12 THEN
                                    IF ZIUA > 31 THEN
                                    ZIUA=1
                                    LUNA=1
    '==================================== display time with :
    '==================================== display time without :
         LcdOut $FE, $80, dec2 HH,":",dec2 MM," ",dec2 ss,"   ",DEC2 ZIUA,"/",DEC2 LUNA
        Col=Col+1
        HzTimer=HzTimer+$7A12
      gosub ReadTemp
    goto Main
    ' SUBROUTINES:
    ReadTemp:
        Sign = TempC.15
        TempC = ABS(TempC)
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        Sign2 = TempC2.15
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    Debounce :
    For Delay= 1 to 200
    Pause 1
    next Delay
    END       					     ' Of program
    and
    DEFINE OSC 4  				   ' using a 4MHz crystal
    DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
    DEFINE LCD_DATAUS 50      ' Data delay time in us
    TempC           var     word
    Float           var     word
    TempC2          var     word
    Float2          var     word
    Delay           var     byte
    Mode            var     byte
    semn		    var     word
    semn2           var     word
    ' setup vars for clock
    Time    VAR BYTE   			  ' accumulates TMR2 to PR2 match counts
    Minutes VAR BYTE   			  ' minutes
    Hours   VAR BYTE   			  ' hours
    Seconds VAR BYTE
    Match   VAR PIR1.1 			  ' TMR2 to PR2 match interrupt flag bit
    CMCON = 7          			  ' disable comparators
    INTCON = 0         			  ' not using interupts. Just monitoring int flag bits
    Time = 0           			  ' clear TMR2 to PR2 match counter
    Hours = 00         			  ' set clock starting hour here
    Minutes = 00       			  ' set clock starting minutes here
    Seconds = 0
    PR2 = 249           			  ' 249 +1 extra cycle for TMR2 reset = 250*5*16*1uS=20mS
    Match = 0           			  ' clear match flag
    ' setup & start TMR2
    T2CON = %00100110   			  ' 1:5 postscale, 1:16 prescale, TMR2 on
       ' every 20mS the TMR2IF flag is set, and this routine is entered.
       ' Plenty of time to do other stuff.
       IF Match THEN           	 	 ' has TMR2 matched PR2? (should happen every 20mS)
          Match = 0           	 	 ' yes. clear TMR2 to PR2 match flag bit
          Time = Time + 1     	 	 ' increment 20mS count
          IF Time = 50 THEN   	 	 ' 50 x 20mS = 1 second
             Time = 0         	 	 ' show time in 1 second intervals
    LcdOut $FE, $80, DEC2 Hours, ":",DEC2 Minutes, ":",DEC2 Seconds,13,10
    Gosub readtemp
    	Seconds = Seconds + 1
          IF Seconds = 60 THEN     	 ' has 60 seconds passed?
             Seconds = 0
             Minutes = Minutes + 1 	 ' increment minute count
             IF Minutes = 60 THEN  	 ' have 60 minutes passed?
                Minutes = 0         	 ' yes. roll-over minutes 00
                Hours = Hours + 1  	 ' update hours
                IF Hours = 24 THEN Hours = 0 ' roll-over hours from 24 to 00
             ENDIF 			 	 ' end IF Minutes = 60
          ENDIF    			 	 ' end IF Seconds = 60
       ENDIF       			 	 ' end IF Match
       GOTO Main
    ReadTemp:
        Sign = TempC.15
        TempC = ABS(TempC)
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        Sign2 = TempC2.15
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    Sorry for long post... It's a proof of hard ( useless ) work...
    Aug 2010
    Maryland, USA
    First thing I would try is take out the gosub readtemp. Just for testing purpose. Then report back, tell us exactly how it is not precision. is it losing 1 second per min. is it gaining 1? what is the output you are seeing?
    BTW, I am looking at the second program
    -Bert
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for atention ! All three programs are - without read_temperature - verry accurate !
    I try, in all three cases, to put the "read_temp" code in other places... the results are inadequates !
    @ first you can try your program with a 9 bits resolution, to have the quickest sensor conversion time ...
    THEN you will know where is something wrong ...
    malc-c's Avatar
    malc-c Guest
    Not checked the data sheet so can't confirm if this is an option, but for the sake of a couple of ££ why not use a DS1307 RTC chip ??
    Aug 2010
    Maryland, USA
    Quote Originally Posted by fratello View Post
    Still waiting to hear what the results are. Is it slow, fast, sometimes right, sometimes wrong? Is it close or all over the place?
    -Bert
    Dec 2008
    Ploiesti, ROMANIA
    The clock run ok without read_temp, in all cases and run faster ( strange for me ) if use this subroutine.
    I try now with 9 bits resolution of DS18B20, wait for result !
    Thanks for support !
    Dec 2008
    Ploiesti, ROMANIA
    If DS18B20 it's in 9 bit mode, the clock run faster (!) with ~ 2 sec/hour (5 sec in 3 hours).
    Thats about .055%; you ARE using a crystal, not a resonator, right?
    Anand
    Dec 2008
    Ploiesti, ROMANIA
    Yes, I use a crystal. But, without code for DS18B20, the clock run correct (~ 1 sec/day).
    If I read this correctly you have an interrupt frequency of 61.035Hz (prescaler 1:64, 256*64=16384, 1/0.016384=61.035Hz) when you ideally should have 61Hz - that's 0.057% off and as Anand says 2 seconds over one hour is 0.055%.
    I currently have no idea why it starts running correct when you remove the DS1820 code - are you sure that's the case?
    Closer to .056, actually since its .055555.. So, you might me spot on..
    Anand
    Dec 2008
    Ploiesti, ROMANIA
    Somebody, in a forum of my country, propose this code. It' work ok, just 1 sec/hour faster !
    @ __config _XT_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    define OSC 4
    wsave   VAR BYTE    $70     SYSTEM
    TempC           var     word
    Float           var     word
    TempC2          var     word
    Float2          var     word
    Delay           var     byte
    Mode            var     byte
    semn          var     word
    semn2           var     word
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System ; Attention ! Modified file !
    INCLUDE "ReEnterPBP.bas"
    DS18B20_1_12bit CON %00011111          ' NOW 9 BIT
    DS18B20_2_12bit CON %00011111          ' NOW 9 BIT
    ZIUA        var   byte
    LUNA        var   byte
    Disp      var   BIt                   ; Disp=1 to update display
    ' Init Sensor 1
    Pause 50
    Pause 50
    ' Init Sensor 2
    Pause 50
    Pause 50
    INT_LIST  macro                ; IntSource,   Label,  Type, ResetFlag?
            INT_Handler     TMR0_INT,  _ISR,   PBP,  yes
        INT_CREATE                ; Creates the interrupt processor
    @   INT_ENABLE   TMR0_INT
    LOOP:
         Pause 50                          ' Debounce
       LcdOut $FE, 1
       PAUSE 500
       LcdOut $FE, 1
       if portb.1=0 then
          Hour=Hour+1
            IF Hour=24 then
              Hour=0
          Gosub Debounce
       if portb.2=0 then
            IF Hour = 0 then
              Hour=24
          Hour=Hour-1
          Gosub Debounce
    EndIf
       if portb.1=0 then
          Second=0
          Minute=Minute+1
            IF Minute=60 THEN
              Minute=0
          Gosub Debounce
       if portb.2=0 then
          Second=0
            IF Minute =<0 THEN
              Minute=60
          Minute=Minute-1
       Gosub Debounce
    EndIf
       if portb.1=0 then
          ziua=ziua+1
                IF LUNA=2 THEN
                      IF ZIUA > 28 THEN
                      ZIUA=1
          Gosub Debounce
       if portb.2=0 then
          ZIUA=ZIUA-1
          Gosub Debounce
    EndIf
       if portb.1=0 then
          luna=luna+1
                if luna>12 then
                luna=1
          Gosub Debounce
       if portb.2=0 then
          luna=luna-1
                if luna<1 then
                luna=12
          Gosub Debounce
    EndIf
    If Mode > 4 then
       PAUSE 100
       mode=0
    EndIf
    IF Disp=1 THEN
    Disp=0
    GOTO LOOP
    @   INT_DISABLE   TMR0_INT
    ISR:
    Ticks=Ticks + 1
    Ticks=0
    IF Second=60 THEN
    Second=0
    IF Minute=60 THEN
    Minute=0
    IF Hour=24 THEN
    Hour=0
    ZIUA=ZIUA+1
              IF LUNA=2 THEN
                   IF ZIUA > 28 THEN
                        ZIUA=1
                        LUNA=3
                   IF ZIUA > 30 THEN
                        ZIUA=1
                        LUNA=LUNA+1
                   IF ZIUA > 31 THEN
                        ZIUA=1
                        LUNA=LUNA+1
             IF LUNA=12 THEN
                   IF ZIUA > 31 THEN
                        ZIUA=1
                        LUNA=1
    Gosub Read_temp
    NoUpdate:
    @ INT_RETURN                ; Re-enable interrupts
    ;Subrutine
    Debounce:
    FOR Delay=1 To 200
    Read_Temp:
        Sign = TempC.15
        TempC = ABS(TempC)
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        Sign2 = TempC2.15
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    Great - as long as it works for your needs.
    But you can't get away from the fact that you're interrupting at 61.035Hz while it ideally should be 61Hz. That little difference WILL make it run fast.
    Let's see.... For a duration of 100.000 interrupts a time of 100,000/61.035=1638.40 seconds have passed. Your code, because it divides by 61, will "display" 1639.34 seconds (the clock runs fast).
    Here's an idea... If you keep a second WORD sized tick counter incrementing in your ISR and when it hits 1754 you reset it to zero and skip updating your normal Ticks variable for that interrupt only. This way, in 100,000 interrupts you'll only increment your Ticks variable 100,000 - (100,000/1754) = 99943 times, resulting in "time" of 99943/61 = 1638.40 seconds - pretty darn close to ideal. The clock will zig-zag a little bit but the period is only about 28 seconds so I don't think you'll notice.
    It's still early here, I may have made some terrible misstake in the math (doesn't have to be early for that). Anyway, it's an idea you may want to look into.
    Dec 2008
    Ploiesti, ROMANIA
    Default If You see one crazy man, it's me !
    I re-re-re-read all the topics on this forum (searching for "timer") and I found one code (Josepino's code) for HIGH-accuracy clock.
    I try to compile them, but I have errors. What I do wrong ?
    DEFINE NO_CLRWDT
    Define	OSC	4
    DEFINE  LCD_DREG        PORTB      ' LCD Data Port
    DEFINE  LCD_DBIT        4      ' Starting Data Bit
    DEFINE  LCD_RSREG       PORTA      ' Register Select Port
    DEFINE  LCD_RSBIT       1      ' Register Select Bit
    DEFINE  LCD_EREG        PORTA      ' Enable Port
    DEFINE  LCD_EBIT        0      ' Enable Bit
    DEFINE  LCD_BITS      4      ' Data Bus Size
    DEFINE  LCD_LINES      2      ' Number of Lines on LCD
    CMCON = 7
    pushButton1 var portb.0 'switch
    pushButton2 var portb.1
    pushButton3 Var portb.2
    pushButton4 Var portb.3
    pressed con 0   		;value of button pressed
    notPressed con 1 		;value of button not pressed
    dhour   var     byte    ' Define display hour variable
    i       var     byte    ' Debounce loop variable
    ticks   var     byte    ' Define pieces of seconds variable
    Seconds  var byte
    Minutes  var byte
    Hours    var byte
    Days     var byte
    Months   var BYTE
    TempC           var     word
    Float           var     word
    TempC2          var     word
    Float2          var     word
    Sign2           var     bit           ' +/- sign
    semn            var     word
    semn2           var     word
    DS18B20_1 CON %01011111
    DS18B20_2 CON %01011111
    ;DS18B20_9bit  CON %00011111         ; 93.75ms, 0.5°C
    ;DS18B20_10bit CON %00111111         ; 187.5ms, 0.25°C
    ;DS18B20_11bit CON %01011111         ; 375ms,   0.125°C
    SecondsChanged   var bit
    MinutesChanged   var bit
    HoursChanged     var bit
    DaysChanged      var bit
    SecondsChanged = 1
    MinutesChanged = 1
        Seconds = 0
        Minutes = 0
        Hours = 12
        Days = 1
        Months = 1
        SecondsChanged = 1
        MinutesChanged = 1
        HoursChanged = 1
        DaysChanged = 1
    include "timp.pbp.txt"
    Pause 200                          ' Wait for LCD to Initialize
    ' Init Sensor 1
    OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_1]
    Pause 50
    Pause 50
    ' Init Sensor 2
    OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_2]
    Pause 50
    Pause 50
    mainloop:
    if tick.0=1 then
    tick.0=0
           SecondsChanged = 1
           if Seconds = 60 then
              MinutesChanged = 1
              Seconds = 0
           if Minutes = 60 then
              Hours = Hours + 1
              HoursChanged = 1
              Minutes = 0
           if Hours = 24 then
              Days = Days + 1
              DaysChanged = 1
              Hours = 0
           if Days = 32 then
              Months = Months + 1
              Days = 1
           if months = 13 then
           months = 1
        ' Check button pressed to set time
        if pushbutton1 = pressed Then
        gosub set_minutes
        if pushbutton2 = pressed then
        gosub set_hours
        if pushbutton4 = pressed then
        gosub set_days
        if pushbutton3 = pressed then
        gosub set_Months
            ' Check for time to update screen
        If SecondsChanged = 1  Then
            SecondsChanged = 0  ' Display time as hh:mm:ss
    LCDout $FE, $80, dec2 Hours,":",dec2 Minutes,":",dec2 Seconds,"   ",DEC2 Days,"/",DEC2 Months
    '                pauseus 1386
        Endif
    Goto mainloop   ' Do it all forever
    set_minutes:
    Minutes = 0
    gosub debounce
    set_hours:
    Hours = Hours + 1
    if Hours = 24 then
    Hours = 0
    gosub debounce
    set_days:
    Days = Days + 1
    if Days = 32 then
    Days = 1
    gosub debounce
    set_months:
    Months = Months +1
    if Months = 13 then
    Months = 1
    gosub debounce
    debounce:
    For i = 1 To 100	' Debounce and delay for 100ms
    	Pause 1	' 1ms at a time so no interrupts are lost
    	Next i
    SecondsChanged = 1
    Read_Temp:
        ' Skip ROM search & do temp conversion
        Sign = TempC.15
        TempC = ABS(TempC)
    IF TempC.15 THEN
    Semn="-"
    Semn="+"
        Sign2 = TempC2.15
    IF TempC2.15 THEN
    Semn2="-"
    Semn2="+"
    and timp.pbp.txt
            INT_Handler   TMR0_INT,   int_handler,   ASM,  yes
        INT_ENABLE  TMR0_INT     ; Enable Timer 1 Interrupts
            OPTION_REG = %00001000	' Set TMR0 configuration
           INTCON = %10100000	' Enable TMR0 interrupts
    		bres_hi	VAR	BYTE bank0 system		' hi byte of our 24bit variable
    		bres_mid	VAR	BYTE bank0 system	'	; mid byte
    		bres_lo	VAR	BYTE bank0 system		'; lo byte
    						'; (we only need 3 bytes for this system)
    bres_hi = $0F
    bres_mid= $42
    bres_lo= $40
    		tick	VAR	BYTE bank0 system
    ;  INTERRUPT HANDLER     (runs this code each timer0 interrupt)
    int_handler				;
    	; Note! we get here every 256 instructions, we
    	; can now do our special one second timing system.
    	; This consists of three main steps;
    	; * subtract 256 counts from our 24bit variable
    	; * test if we reached the setpoint
    	; * if so, add 1,000,000 counts to 24bit variable and generate event.
    						; * optimised 24 bit subtract here
    						; This is done with the minimum instructions.
    						; We subtract 256 from the 24bit variable
    						; by just decrementing the mid byte.
    	tstf bres_mid			; first test for mid==0
    	skpnz				; nz = no underflow needed
    	decf bres_hi,f			; z, so is underflow, so dec the msb
    	decfsz bres_mid,f		; dec the mid byte (subtract 256)
    						; now the full 24bit optimised subtract is done!
    						; this is about 4 times faster than a "proper"
    						; 24bit subtract.
    	goto int_exit			; nz, so definitely not one second yet.
    						; in most cases the entire 'fake" int takes
    						; only 9 instructions.
    						; * test if we have reached one second.
    						; only gets here when mid==0, it MAY be one second.
    						; only gets to here 1 in every 256 times.
    						; (this is our best optimised test)
    						; it gets here when bres_mid ==0.
    	tstf bres_hi			; test hi for zero too
    	skpz					; z = both hi and mid are zero, is one second!
    	goto int_exit			; nz, so not one second yet.
    	; Only gets to here if we have reached one second.
    	; now we can generate our one second event, like add
    	; one second to our clock or whatever.
    	; (in this example we toggle a led)
    	; The other thing we need to do is add 1,000,000 counts
    	; to our 24bit variable and start all over again.
    						; Add the 1,000,000 counts first.
    						; One second = 1,000,000 = 0F 42 40 (in hex)
    						; As we know hi==0 and mid==0 this makes it very fast.
    						; This is an optimised 24bit add, because we can
    						; just load the top two bytes and only need to do
    						; a real add on the bottom byte. This is much quicker
    						; than a "proper" 24bit add.
    	movlw 0x0F			; get msb value
    	movwf bres_hi			; load in msb
    	movlw 0x42			; get mid value
    	movwf bres_mid			; load in mid
    	movlw 0x40			; lsb value to add
    	addwf bres_lo,f		; add it to the remainder already in lsb
    	skpnc				; nc = no overflow, so mid is still ok
    	incf bres_mid,f		; c, so lsb overflowed, so inc mid
    						; this is optimised and relies on mid being known
    						; and that mid won't overflow from one inc.
    						; that's it! Our optimised 24bit add is done,
    						; this is roughly twice as quick as a "proper"
    						; 24bit add.
    						; now we do the "event" that we do every one second.
    						; Note! for this example we toggle a led, which
    						; will give a flashing led which is on for a second
    						; and off for a second.
    						; Add your own code here for your one second event.
    						; Note! My led is on porta,3
    						; your led may be on a different pin.
      movlw b'00000001'		; mask for bit 3
      xorwf tick,f			; toggle PORTA,bit3 (toggle the led)
    	; now our one second event is all done, we can exit the
    	; interrupt handler.
    						; finally we restore w and status registers.
    						; also clears TMRO int flag now we are finished.
    int_exit
    	INT_RETURN
    I have not tested it, but me thinks:
    is a NO NO.
    Try using a unique name to name your handler.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support ! I changed the name, but...
    It compiles here. I renamed the interrupt handler to ISR (changed the label) and adjusted the DT-Ints declaration accordingly:
            INT_Handler   TMR0_INT,   ISR,   ASM,  yes
        INT_ENABLE  TMR0_INT     ; Enable Timer 0 Interrupts
    And
    ISR
    I compiled it for a 16F628A for which I had to add
    INCLUDE DT_Ints-14.bas
    wsave1 VAR BYTE $A0 SYSTEM
    wsave2 var BYTE $120 SYSTEM
    Make sure your compiling "from" the main source file and not from within the timp.pbp.txt file.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support ! Yes, in this way I compiled the code. Unfortunately the result are so strange ...the display show random numbers - quickly changed, the errors messages are without end
    Dec 2008
    Ploiesti, ROMANIA
    OK, now the code for clock works fine now.
    Let's return to my sheeps ...How can I put in "timp.pbp.txt" the code for reading the two DS18B20 ? The author say : "Add your own code here for your one second event". How can I make this ? I don't have a clue...
            INT_HANDLER  TMR0_INT,  PISR,   ASM,  yes
    		bres_mid	VAR	BYTE bank0 system		; mid byte
    		bres_lo	VAR	BYTE bank0 system		; lo byte
    bres_hi = $0F
    bres_mid= $42
    bres_lo= $40
    PISR			;
    int_exit
    	INT_RETURN
    Dec 2008
    Ploiesti, ROMANIA
    This is my solution. Maybe not correct, but...accuracy is VERY good !
    I read the sensors (each) twice in a minute ; i add the timex variable, for increase 'the duration' of seconds when PIC read sensors, in step of 200 us. From various tests (many guys from one romanian electronics forum) , with 800 us the clock run correct !
    Every advice it's wellcome !
    	if seconds=20 or seconds=50 then              'read first DS18B20
    		intcon.7=0
    		gosub temp_1
    			for i=1 to timpx
                      pauseus 200
    			next i
    		intcon.7=1
    	if seconds=25 or seconds=55 then              'read second DS18B20
    		intcon.7=0
    		gosub temp_2
    			for i=1 to timpx
    			pauseus 200
    			next i
    		intcon.7=1
