examine string
Results 1 to 5 of 5
Thread: examine string
    Mar 2008
    Default examine string
    I don't see any way to work with strings in PBP.
    I have strings such as "11000011", I need to look at each position and if it is a 1 do something
    and if it is a zero do something else. Also, what is PBPL? I would like to use Long data type but it's only available in PBPL.
    Bob Hiller
    May 2008
    Italy
    The following simple snippet will solve your problem.
    My_Byte = "11000011"
    For B0 = 0 to 7
    If My_Byte0.[B0] = 1 then DO SOMETHING
    Else
    DO SOMETHING ELSE
    Next B0
    Cheers
    Al.
    PBPL allows you to use LONG type variables, 32 bit numbers. LONGS can only be used with 18Fxxx chips and was a new feature with PBP 2.50.
    Mar 2008
    I can't get this to work, I fixed what I thought where some typo's but not sure how to define this, it doesn't like the quotation marks.
    Quote Originally Posted by aratti View Post
    For B0 = 0 to 7
    Else
    DO SOMETHING ELSE
    Next B0
    Cheers
    Al.
    My_Byte = %11000011
