RFID example.
Results 1 to 3 of 3
Thread: RFID example.
    Jan 2011
    Default RFID example.
    can anybody share the RFID read and write code example? and also the hardware used..thanks.
    ashoksharma's Avatar
    ashoksharma Guest
    this is code for reading rfid using 8051 microcontroller
    //Program to interface RFID with 8051 microcontroller (AT89C51) #include<reg51.h>
    unsigned int data_out,command=0x80,temp;
    sfr lcd_data_pin=0xA0; //P2 port
    sbit rs=P1^0; //Register select
    sbit rw=P1^1; //Read/Write
    sbit en=P1^2; //Enable pin
    unsigned char card_id[12];
    void delay(unsigned int count) //Function to provide delay
    int i,j;
    for(i=0;i<count;i++)
    for(j=0;j<1275;j++);
    void lcd_command(unsigned char comm) //Lcd command funtion
    lcd_data_pin=comm;
    en=1;
    rs=0;
    rw=0;
    delay(1);
    en=0;
    void lcd_data(unsigned char disp) //Lcd data function
    lcd_data_pin=disp;
    en=1;
    rs=1;
    rw=0;
    delay(1);
    en=0;
    lcd_string(unsigned char *disp) //Function to send string
    int x;
    for(x=0;disp[x]!=0;x++)
    lcd_data(disp[x]);
    void lcd_ini() //Function to initialize the LCD
    lcd_command(0x38);
    delay(5);
    lcd_command(0x0F);
    delay(5);
    lcd_command(0x80);
    delay(5);
    void recieve() //Function to recieve data serialy from RS232
    unsigned char k;
    for(k=0;k<12;k++)
    while(RI==0);
    card_id[k]=SBUF;
    RI=0;
    void main()
    int l;
    TMOD=0x20; //Enable Timer 1
    TH1=0XFD;
    SCON=0x50;
    TR1=1; // Triggering Timer 1
    lcd_ini();
    lcd_command(0x81); //Place cursor to second position of first line
    lcd_string("UNIQUE CARD ID:");
    delay(200);
    while(1)
    recieve();
    lcd_command(0xC1); //Place cursor to second position of second line
    for(l=0;l<12;l++)
    lcd_data(card_id[l]);
    visit the link for more details RFID Interfacing
    Jan 2011
    Default Re: RFID example.
    I want the example use the UART interface to communicate with the Microcotroller. I plan to use the PIC16F series Microcontroller. and the Reader is use MIFARE. can read and write. what i want to do is the reader can do the increment manually by using the computer and decrement automatic by using the microcontroller.
    anyone if have knowledge on this, please help me and share ur knowledge to me.
    thank you.
