PIC16F506 Problems
Results 1 to 9 of 9
    Jan 2011
    Sydney, Australia
    Default PIC16F506 Problems
    Hi All,
    I am having some difficulties running anything on a PIC16F506.
    The intended project was to display some information on a 16x2 LCD display but after I couldn't get that to work I went back to basics and tried a simple "Blink" program. I have tried the following code using an external (crystal) oscillator as well as the internal oscillator but get absolutely nothing happening on the LED. (the LED circtuit works perfectly when connected/driven manually)
    Led var PORTC.0
    TRISC=0
    Again:
    Led=1
    Pause 1000
    Led=0
    Pause 1000
    Goto Again
    I am quite confused as to why this simple program will not work on the 16F506 when I can get it to work on others (eg 16F84A, 16F628A, 16F716 tec.)
    Is there something peculiar about using the 16F506 that I am missing?
    Any help would be greatly appreciated.
    Cheers
    Barry
    That chip has comparators that need turned off when not using them.
    Try adding near the top of your code
    CM1CON0 = 0
    CM2CON0 = 0
    Jan 2011
    Sydney, Australia
    Thanks Dave - that seems to have solved my problem.
    Now to move on to the LCD display section followed (hopefully) soon after by the A/D section.
    Cheers
    Barry
    COOL!!!
    Keep the data sheet handy
    Jan 2011
    Sydney, Australia
    Things are progressing well with the extension of my project but I have hit a bit of a snag.
    I have the the A/D working on PORTB.0 and I can do all the standard "Hello World" type stuff with the LCD. My problem occurs when I try to display the result of the A/D conversions.
    The relevant code extract is as follows:
    adval var byte ' Create adval to store result
    ADCON0 = %11110001 ' Set clock divisor to INTOSC/4
    ' Set AN0, AN1 and AN2 as Analogue Input
    ' Turn on A/D converter
    CM1CON0 = 0 ' Disable comparator
    CM2CON0 = 0 ' Disable comparator
    OPTION_REG.5 = 0 ' Set PORTC.5 as digital I/O port
    TRISC = 0 ' Set PORTC as all outputs
    TRISB = %00000111 ' Set PORTB.0, PORTB.1 and PORTB.3 as inputs
    Pause 500 ' Wait .5 second
    loop: ADCIN 0, adval ' Read channel 0 to adval
    LCDOUT $fe, 1 ' Clear LCD
    LCDOUT "Value: ", DEC adval ' Display the decimal value
    Pause 100 ' Wait .1 second
    Goto loop ' Do it forever
    When I try to compile this program using MPLAB IDE I get the following error
    Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z -p16F506 "ADCIN8 16F506.bas"
    PICBASIC PRO(TM) Compiler 2.47, (c) 1998, 2006 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Macro LCDOUTCOUNT?C not found in macro file.
    ERROR: Macro LCDOUTNUM?B not found in macro file.
    ERROR: Macro LCDOUTDEC? not found in macro file.Halting build on first failure as requested.
    BUILD FAILED: Mon Jan 17 21:22:24 2011
    but when I change the LCDOUT statement to
    LCDOUT "Value: ", #adval
    everything works perfectly.
    I was led to believe that the two statements are the same so why doesn't it work?
    Frustratingly, LCDOUT "Value: ", DEC adval works perfectly when compiling fo 16F684 or 16F716 but not 16F506.
    Can anyone shed some light on this?
    The final program will use Darrel Taylor's Bargraph display and my initial compile resulted in a host of LCDOUT error statements (DEC, REP issues) so I need to get to the bottom of this problem. (BTW, I can get Darrel's bargraph working beautifully on 16F684, 16F716 etc).
    Cheers
    Barry
    SEROUT2 type modifiers aren't supported for 12-bit core device types.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
