[QUOTE=charudatt]Hello Ron,
I think that is the case !. Because , its not that I am not getting anything out, but just that its Garbage.
Can you suggest how to use the INTOSC Config in the code.
An easier way to do it, is to find out if the rate is too fast or too slow. This can be done with a frequency meter. If it is, for arguement sake, too fast, I would do a for next loop incrementing the serin2 baud rate number by one, until the character or word coming out of the pin is the right one.
Example: For A = 1 to 100
Serout2 pin,32768 + A,[dec A, "test"]
Next A
On the receive side, you should get the right number and right date when the baud rate is correct. Just add the number ti the baud number and all will be right with the world. If you don't have access to a meter, then try it above and below the proper number.
