NTC thermistor temperature sensing
Results 1 to 37 of 37
    Sorry ...
    But my Easy Pic5 outputs " ITS : ...00.00°C " with all the processor settings I gave you in previous code, but 10 bits ADC ... ( Whistle and Bells ... )
    I also asked for printing ntc Value ...
    comprised between 0 and 1023 ...
    try this :
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    TRISA=%11111111
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc
    if tb0 >= 16170 then
    tb1 = tb0-16170
    tb1 = 0
    tb1 = tb1*100
    tb2 = Div32 634
    tb0 = tb2/100
    tb1 = tb2//100
    LCDOUT $FE,2,DEC4 ntc
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC2 tb1,"°C"
    goto lp
    so ... take your own conclusions !!!
    Sorry ...
    try this :
    Your code works, but it still show ADC values>1024... or less on my PIC (for exemple 1616 for 24,26°C)...
    The temperature reading is correct.
    One more thing ...
    The compiler doesn't like " ° " ( "Maj" + "=" ) character ...
    better use
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC2 tb1, 223, "C"
    where 223 ( sometimes 178 ) is supposed to be the ASCII code of " ° " ...
    That said ... ADC value NEVER is > 1023 ...
    from your firsts explanations ( post #1) ... I get That : ( 16F877A on EasyPic5 )
    DEFINE ADC_BITS 10      ' Set number of bits in result
    DEFINE LCD_DREG PORTB       ' Set LCD Data port
    DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus .7
    DEFINE LCD_RSREG PORTB      ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT 5           ' Set LCD Enable bit i.e, PORTE.4
    DEFINE LCD_BITS 4           ' Set LCD bus size ot 4 bit Upper Nibble (4 or 8 bits)
    DEFINE LCD_LINES 2         ' Set number of lines on LCD to 4 Lines
    TRISA  = %11111111
    TRISB  = 0
    TRISC  = 0
    CMCON  = 7
    ADCON0 = %11000001
    ADCON1 = %10000100
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc * 33 /92
    tb1 = tb0*721
    tb2 = Div32 255
    tb2 = tb2 - 64
    tb0 = tb2/10
    tb1 = tb2//10
    PAUSE 200
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC1 tb1,178,"C"
    goto lp
    Gives me a 0 - 100°C scale for adc = 67 to 1023 ...
    so, i suppose it to be " not so bad , but to confirm "
    One more thing ...
    better use
    TRISA  = %11111111
    TRISB  = 0
    TRISC  = 0
    CMCON  = 7
    ADCON0 = %11000001
    ADCON1 = %10000100
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc * 33 /92
    tb1 = tb0*721
    tb2 = Div32 255
    tb2 = tb2 - 64
    tb0 = tb2/10
    tb1 = tb2//10
    PAUSE 200
    goto lp
    Ok, my problem is largely solved, and if change my PIC, I'll be warn of ADC values. I think my PIC is a special case.
    Thanks everyone.
    Epilog ...
    for general knowledge ... a look at Microchip AN 942 may be valuable ...
