NTC thermistor temperature sensing
Results 1 to 37 of 37
    But this time I think the sim is correct. I think you ment to set ADCON2, not ADCON1. ADCON 2 sets right or left justified. Default is left justified.
    How do you right-justify bits?
    tb0=ntc>>8?
    Or there is an another command?
    Aug 2010
    Maryland, USA
    Quote Originally Posted by pxidr84 View Post
    tb0=ntc>>8?
    Look at the datasheet for ADCON2. I feel like the setting you have for ADCON1 is really ment for ADCON2. ADCON1 only has 2 valid bits. Not the 2 you have set.
    BTW, tb0=ntc>>8 will shift it 8 places. you would only need to shift 6 times. Yes this will work, but better to just set the registers up for what you want, then no un-needed code
    -Bert
