NTC thermistor temperature sensing
Results 1 to 37 of 37
    Aug 2010
    Maryland, USA
    You should place a patent on this one ...
    In case you are wondering why, the ADC is 10 bit, so clearly you can't have 16 bit result from the ADC
    -Bert
    It's weird. I got a 16-bit result. Why? Code :
    define OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 10
    DEFINE LCD_DREG PORTC
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 5
    DEFINE LCD_COMMANDUS 10000'Command delay time in us
    DEFINE LCD_DATAUS 1000 'Data delay time in us
    ntc VAR WORD
    TRISA=%11111111
    ADCON1=%10000010
    PAUSE 4000
    lp:
    ADCIN 1,ntc
    PAUSE 100
    Lcdout $fe,$c0,#ntc
    goto lp
    you do not display Tb0 ( as the ADC result ) , but Tb0
    And what are the differences between Tb0 and Tb0? I didn't understand your answer.
    Never trust a sim.
    Try it in real life and come back.
    ADCIN 1,tb0
    tb1=tb0-16170
    tb1=tb1*tb3
    tb2=Div32 634
    tb0=tb2/100
    tb1=tb2//100
    see any difference between Tb0 value @ line 1 and Tb0 Value @ line 5 ???
    really no ?
    Never trust a sim.
    In real life with the same code:
    really no ?
    My updated code :
    define OSC 20
    DEFINE ADC_BITS 10
    DEFINE LCD_EBIT 5
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    TRISA=%11111111
    ADCON1=%10000010
    PAUSE 4000
    lp:
    ADCIN 1,ntc
    tb0=ntc
    if tb0>=16170 then
    tb1=tb0-16170
    tb0=0
    tb1=tb1*100
    tb2=Div32 634
    tb0=tb2/100
    tb1=tb2//100
    PAUSE 100
    Lcdout $fe,$c0,"ITS: ",DEC (tb0 DIG 1),DEC (tb0 DIG 0),".",DEC (tb1 DIG 1),"°C"
    goto lp
    I was surprised because the previous code worked good.
    Aug 2010
    Maryland, USA
    Never trust a sim.
    But this time I think the sim is correct. I think you ment to set ADCON2, not ADCON1. ADCON 2 sets right or left justified. Default is left justified.
    -Bert
    How do you right-justify bits?
    tb0=ntc>>8?
    Or there is an another command?
    Aug 2010
    Maryland, USA
    Quote Originally Posted by pxidr84 View Post
    tb0=ntc>>8?
    Look at the datasheet for ADCON2. I feel like the setting you have for ADCON1 is really ment for ADCON2. ADCON1 only has 2 valid bits. Not the 2 you have set.
    BTW, tb0=ntc>>8 will shift it 8 places. you would only need to shift 6 times. Yes this will work, but better to just set the registers up for what you want, then no un-needed code
    -Bert
    May 2008
    Italy
    From your code:
    ADCIN 1,ntc
    tb0=ntc
    if tb0>=16170 then
    tb1=tb0-16170
    tb0=0
    Since ntc could be 0 or 1023 maximum, the condition if tb0>=16170 then is always false so tbo will be always zero and tb1 will be never setted with your required calculation tb1=tb0-16170.
    Cheers
    Al.
    Quote Originally Posted by aratti View Post
    From your code:
    ADCIN 1,ntc
    tb0=ntc
    if tb0>=16170 then
    tb1=tb0-16170
    tb0=0
    Cheers
    Al.
    The code works for me because the value of my ADC varies from 0 to 65525 (it's a 10-bit ADC, but with bits shifted to a 16-bit value).
    Sorry ...
    But my Easy Pic5 outputs " ITS : ...00.00°C " with all the processor settings I gave you in previous code, but 10 bits ADC ... ( Whistle and Bells ... )
    I also asked for printing ntc Value ...
    comprised between 0 and 1023 ...
    try this :
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    TRISA=%11111111
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc
    if tb0 >= 16170 then
    tb1 = tb0-16170
    tb1 = 0
    tb1 = tb1*100
    tb2 = Div32 634
    tb0 = tb2/100
    tb1 = tb2//100
    LCDOUT $FE,2,DEC4 ntc
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC2 tb1,"°C"
    goto lp
    so ... take your own conclusions !!!
    Sorry ...
    try this :
    Your code works, but it still show ADC values>1024... or less on my PIC (for exemple 1616 for 24,26°C)...
    The temperature reading is correct.
    One more thing ...
    The compiler doesn't like " ° " ( "Maj" + "=" ) character ...
    better use
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC2 tb1, 223, "C"
    where 223 ( sometimes 178 ) is supposed to be the ASCII code of " ° " ...
    That said ... ADC value NEVER is > 1023 ...
    from your firsts explanations ( post #1) ... I get That : ( 16F877A on EasyPic5 )
    DEFINE ADC_BITS 10      ' Set number of bits in result
    DEFINE LCD_DREG PORTB       ' Set LCD Data port
    DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus .7
    DEFINE LCD_RSREG PORTB      ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT 5           ' Set LCD Enable bit i.e, PORTE.4
    DEFINE LCD_BITS 4           ' Set LCD bus size ot 4 bit Upper Nibble (4 or 8 bits)
    DEFINE LCD_LINES 2         ' Set number of lines on LCD to 4 Lines
    TRISA  = %11111111
    TRISB  = 0
    TRISC  = 0
    CMCON  = 7
    ADCON0 = %11000001
    ADCON1 = %10000100
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc * 33 /92
    tb1 = tb0*721
    tb2 = Div32 255
    tb2 = tb2 - 64
    tb0 = tb2/10
    tb1 = tb2//10
    PAUSE 200
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC1 tb1,178,"C"
    goto lp
    Gives me a 0 - 100°C scale for adc = 67 to 1023 ...
    so, i suppose it to be " not so bad , but to confirm "
