NTC thermistor temperature sensing
Results 1 to 37 of 37
    Default NTC thermistor temperature sensing
    Hello everyone,
    I use with my PIC a simple NTC thermistor in series with a 2.2k thermistor (to make a voltage divider), then I fed the ADC1 port.
    The ADC reading works well, with a 8-bit setting (values from 0 to 255 in function of temperature).
    Now I want to convert this number into degrees celcius, so I will use this function :
    ADCIN 1,adcVar
    ADCVoltage=adcVar/78 (255/3.3=78)
    temp=(ADCVoltage-0.8143)/0.0319
    But I'm aware that PBP don't handle float numbers. Here's my code :
    ' Set PORTA to all input
    TRISA = %11111111
    ' Set up ADCON1
    ADCON1 = %10000010
    define OSC 20
    DEFINE ADC_BITS 8 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 10 ' Set sampling time in microseconds
    DEFINE LCD_DREG PORTC 'LCD data port
    DEFINE LCD_RSREG PORTC 'LCD data port
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 10000'Command delay time in us
    DEFINE LCD_DATAUS 1000 'Data delay time in us
    adcVar VAR WORD
    adcVoltage VAR WORD
    temp VAR WORD
    Pause 4000
    Lcdout "Thermometer"
    pause 4000
    ADCIN 1,adcVar
    Pause 100
    lcdout $fe,1
    lcdout #adcvar
    lcdout $fe,$c0
    lcdout 1,#temp
    GoTo main
    I can read correctly ADC value on the LCD display (which changes as function of temperature).
    But I like to display on the LCD the temperature with a float number (XX.YY °C).
    But I don't know how to proceed. Can you arrange the code for me? Thanks in advance.
    IF you want to show 1/100 ° ...
    better finely tune your calculations @ first :
    255/ 3.3 = 77.272727 ... not 78 !!!
    PBP can handle ADRes * 2550 / 33 ... sooooooo ...
    add to that , here, a linear regression is not the best for a thermistor, and we conclude you will show " something " , but nothing that could be called a temperature.
    and I don't talk about the least digit meaning ...
    just my two cents ...
    Well, sorry for these newbie questions...
    The precision for my thermoter is not critical, is just a temperature sensor for security purposes. But I want to keep the code for current and voltage sensing purposes (linear curves), so in these cases I need more precision...
    I've read many exemples given... I've modified my code in consequence, I can read the integer part (like 23.00 °C), but not the float part...
    Here's my code :
    define OSC 20
    DEFINE LCD_EBIT 5
    AD_AN1_VALUE VAR WORD
    B0 VAR WORD
    B1 VAR WORD
    B2 VAR WORD
    B3 VAR WORD
    TRISA = %11111111
    ADCON1 = %10000010
    PAUSE 4000
    lp:
    ADCIN 1, AD_AN1_VALUE
    B0 = AD_AN1_VALUE*129
    B1 = B0-8143
    B2 = B1/319
    PAUSE 100
    LCDOUT $fe,1
    LCDOUT #AD_AN1_VALUE
    Lcdout $fe,$c0,"Temp.: ",DEC (B2 DIG 0),DEC (B2 DIG 1),".",DEC (B2 DIG 2),DEC (B2 DIG 3),"°C"
    goto lp
    I like to have XX.Y °C (23.2 °C for example).
    I know that is a very common problem, but I've spend many hours to try solve this, so...
    Example of my calculation :
    AD_AN1_VALUE=137
    B0=137*129=17673
    B1=17673-8143=9530
    B2=9530/319=29,874 °C
    But here I only get 29,00 °C...
    No problem with the newbie questions, just figured a search would get you there.
    Powers of ten...
    If you are using an 18F chip it is easy with LONG type variables.
    Make the 9530, 953000, mult by 100.
    then
    953000 / 319 = 2987
    then
    do the DIG.
    What chip are you using?
    Oct 2010
    PBP can only handle integer, it clips off the .874 dec portion.
    where analog in is 0-1024 I would do something like this, tho your scaling would vary :
    Analog_In_1:
    ADCIN 1, AIN1
    Volts_1=AIN1*50/51/2
    Start_Seconds=AIN1*50/51/2
    HI_1 = Volts_1/100
    LOW_1 = Volts_1//100
    Lcdout $fe,$c0,"Temp.: ",#HI_1,".",#LOW_1,"°C"
    So work in values*100
    Divide by 100 for the integer
    get the modulus of the Divide by 100 for the floating portion
    if you support longs even better!
    note // is modulus
    I thought B0 was reserved for Byte zero, but I may be thinking of something else.
    not much better ...
    B0 VAR WORD
    B1 VAR WORD
    B2 VAR WORD
    B3 VAR WORD
    B3 = 100
    TRISA  = %11111111
    PAUSE 4000
    lp:
    B1 = B0 - 8143
    B1 = B1 * B3
    B2 = Div32 319
    PAUSE 100
    B0 = B2 / 100   ' we get integer part of temp
    B1 = B2 // 100  ' we get the decimal part x 100
    LCDOUT $fe,1
    Lcdout $fe,$c0,"Temp.: ",DEC (B0 DIG 1),DEC (B0 DIG 0),"." ,DEC (B1 DIG 1),DEC (B1 DIG 0),"°C"
    goto lp
    But with whisles and Bells ...
    Oct 2010
    I'm not seeing what "DEC" and "dig" offers over my ver.....
    Please enlighten me!
    Oops, sorry Picguy (I thought you were the original poster....
    Last edited by ScaleRobotics; - 14th January 2011 at 21:18. Reason: Trying to get my foot out of my mouth.
    http://www.scalerobotics.com
    not much better ...
    B0 VAR WORD
    B1 VAR WORD
    B2 VAR WORD
    B3 VAR WORD
    B3 = 100
    TRISA  = %11111111
    PAUSE 4000
    lp:
    B1 = B0 - 8143
    B1 = B1 * B3
    B2 = Div32 319
    PAUSE 100
    LCDOUT $fe,1
    goto lp
    Thank you so much, it works flawlessly now. Very helpful.
    For mackrackit, I use the 18F26K20 (3.3V, 64MHz, 28-DIP), but I will switch to 18F4431 (because mine haven't enough I/O ports, and not enough hardware PWM ports).
    Oct 2010
    I appreciate you saying that, thank you. But my questions stand, AND I have read the manual. My version SEEMS more succinct than the dig / dec version. However, I assume there are advantages to that style, I'm just not seeing them.
    Please point them out to me.
    Quote Originally Posted by Plcguy View Post
    As for me, I missed your earlier post first, hence my foot in my mouth. But now that I look closer at it, if your //100 remainder is 9, then you will print out xx.9. In Alain's example dig 1 will be 0, dig 0 will be 9, so his result will be xx.09.
    Walter
    Oct 2010
    You're right, thank you!
    I have an app in test right now that needs to be fixed!
    Nothing like a second set of eyes.
    Oct 2010
    I also asked earlier about B0.
    Isn't that a special word in BS2?
    And since that is a PBasic off shoot, I'd think it's bad here???
    I looked in the manual and they use B0 as a byte in examples, but it may just be convenient.
    Not sure what you mean about offshoot?
    B0 is just a variable here.
    Quote Originally Posted by pxidr84 View Post
    IF you use a 18F series, it would be much better to make temp calculations with LONG types ... and then use 10 bits ADC result.
    you could easily get a .1°C resolution ( here it is .4°C ... I'm sure you had noticed ! )
    Hi, PlcGuy
    The Goal here is to offer solutions showing the differents uses of PBP and try to make people understand what they do ... not to show as-is the - so called - " best " solution.
    Pxidr84 had chosen this way of displaying its numbers ... no need to change it, as long as he understands what he does. - I perfectly know it is not the shorter or easier or smarter or .... way of doing it. And we do not talk about Walter's # 12 post ...
    The question was about scaling a value ... whithout knowing the Pic type, I showed the DIV 32 use ... which is the simpler for him.
    Darrel posted about "BIG Numbers" operations ... and it is the way to get more decimals here ... but not so simple - for a newbee !!!
    Now, We Know it is a Pic 18F ... the use of LONGs becomes obvious. It still is easy to use.
    I see in your example you just display the ADC input voltage, and not the required temp value, what could raise more questions than offer ideas, for a PBP "newbee" as our friend, as you didn't tell him it doesnt give the awaited result ...
    but was just an example.
    Not so easy to give a useful and usable answer to a post ... don't you think ???
    PS: for B0, B1 .... absolutely no problem till you do not use the BS1 or 2 to include " compatibility files " ...
    Okay, I've rectified the code for use the 10-bit ADC. Now I get more accurate temperature measurement.
    I've also modified the temperature formula (the bin->voltage conversion is now "integrated" within), so I don't need anymore the bin->voltage calculation effetued by the PIC.
    define OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE LCD_EBIT 5
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    tb3 VAR WORD
    tb3=100
    TRISA=%11111111
    ADCON1=%10000010
    PAUSE 4000
    lp:
    ADCIN 1,tb0
    tb1=tb0-16170
    tb1=tb1*tb3
    tb2=Div32 634
    tb0=tb2/100
    tb1=tb2//100
    PAUSE 100
    Lcdout $fe,$c0,"IGBT t.: ",DEC (tb0 DIG 1),DEC (tb0 DIG 0),".",DEC (tb1 DIG 1),"°C"
    goto lp
    I'm somewhat affraid ...
    ADCIN 1,tb0
    tb1=tb0-16170
    tb1=tb1*tb3
    tb2=Div32 634
    tb0=tb2/100
    tb1=tb2//100
    0 < Tb0 < 1024 ... ok ?
    1024 - 16170 = ??? - 15146 !!!
    so, tb1 is NEGATIVE ...
    and PBP do not deal with negative numbers .... but " read " it as 65536 -15146 = ???
    a hole in the somewhere ???
    Well, the ADC range is not 0-1024, but 0-65535...
    (verified with a display of the raw ADC value).
    Alain never said the ADC range was 0 - 65535.
    He was telling you how the value would be acted on.
    You should place a patent on this one ...
    Hurry up !!!
    PS you do not display Tb0 ( as the ADC result ) , but Tb0 ( after - false - calculations done ! ) ....
    Aug 2010
    Maryland, USA
    In case you are wondering why, the ADC is 10 bit, so clearly you can't have 16 bit result from the ADC
    -Bert
    It's weird. I got a 16-bit result. Why? Code :
    define OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE LCD_EBIT 5
    ntc VAR WORD
    TRISA=%11111111
    ADCON1=%10000010
    PAUSE 4000
    lp:
    ADCIN 1,ntc
    PAUSE 100
    Lcdout $fe,$c0,#ntc
    goto lp
    And what are the differences between Tb0 and Tb0? I didn't understand your answer.
    Never trust a sim.
    Try it in real life and come back.
    ADCIN 1,tb0
    tb1=tb0-16170
    tb1=tb1*tb3
    tb2=Div32 634
    tb0=tb2/100
    tb1=tb2//100
    see any difference between Tb0 value @ line 1 and Tb0 Value @ line 5 ???
    really no ?
    Never trust a sim.
    In real life with the same code:
    really no ?
    My updated code :
    define OSC 20
    DEFINE ADC_BITS 10
    DEFINE LCD_EBIT 5
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    TRISA=%11111111
    ADCON1=%10000010
    PAUSE 4000
    lp:
    ADCIN 1,ntc
    tb0=ntc
    if tb0>=16170 then
    tb1=tb0-16170
    tb0=0
    tb1=tb1*100
    tb2=Div32 634
    tb0=tb2/100
    tb1=tb2//100
    PAUSE 100
    Lcdout $fe,$c0,"ITS: ",DEC (tb0 DIG 1),DEC (tb0 DIG 0),".",DEC (tb1 DIG 1),"°C"
    goto lp
    I was surprised because the previous code worked good.
    Aug 2010
    Maryland, USA
    Never trust a sim.
    But this time I think the sim is correct. I think you ment to set ADCON2, not ADCON1. ADCON 2 sets right or left justified. Default is left justified.
    -Bert
    How do you right-justify bits?
    tb0=ntc>>8?
    Or there is an another command?
    Aug 2010
    Maryland, USA
    tb0=ntc>>8?
    Look at the datasheet for ADCON2. I feel like the setting you have for ADCON1 is really ment for ADCON2. ADCON1 only has 2 valid bits. Not the 2 you have set.
    BTW, tb0=ntc>>8 will shift it 8 places. you would only need to shift 6 times. Yes this will work, but better to just set the registers up for what you want, then no un-needed code
    -Bert
    May 2008
    Italy
    From your code:
    ADCIN 1,ntc
    tb0=ntc
    if tb0>=16170 then
    tb1=tb0-16170
    tb0=0
    Since ntc could be 0 or 1023 maximum, the condition if tb0>=16170 then is always false so tbo will be always zero and tb1 will be never setted with your required calculation tb1=tb0-16170.
    Cheers
    Al.
    Quote Originally Posted by aratti View Post
    From your code:
    ADCIN 1,ntc
    tb0=ntc
    if tb0>=16170 then
    tb1=tb0-16170
    tb0=0
    Cheers
    Al.
    The code works for me because the value of my ADC varies from 0 to 65525 (it's a 10-bit ADC, but with bits shifted to a 16-bit value).
    Sorry ...
    But my Easy Pic5 outputs " ITS : ...00.00°C " with all the processor settings I gave you in previous code, but 10 bits ADC ... ( Whistle and Bells ... )
    I also asked for printing ntc Value ...
    comprised between 0 and 1023 ...
    try this :
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    TRISA=%11111111
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc
    if tb0 >= 16170 then
    tb1 = tb0-16170
    tb1 = 0
    tb1 = tb1*100
    tb2 = Div32 634
    tb0 = tb2/100
    tb1 = tb2//100
    LCDOUT $FE,2,DEC4 ntc
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC2 tb1,"°C"
    goto lp
    so ... take your own conclusions !!!
    Sorry ...
    try this :
    Your code works, but it still show ADC values>1024... or less on my PIC (for exemple 1616 for 24,26°C)...
    The temperature reading is correct.
    One more thing ...
    The compiler doesn't like " ° " ( "Maj" + "=" ) character ...
    better use
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC2 tb1, 223, "C"
    where 223 ( sometimes 178 ) is supposed to be the ASCII code of " ° " ...
    That said ... ADC value NEVER is > 1023 ...
    from your firsts explanations ( post #1) ... I get That : ( 16F877A on EasyPic5 )
    DEFINE ADC_BITS 10      ' Set number of bits in result
    DEFINE LCD_DREG PORTB       ' Set LCD Data port
    DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus .7
    DEFINE LCD_RSREG PORTB      ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT 5           ' Set LCD Enable bit i.e, PORTE.4
    DEFINE LCD_BITS 4           ' Set LCD bus size ot 4 bit Upper Nibble (4 or 8 bits)
    DEFINE LCD_LINES 2         ' Set number of lines on LCD to 4 Lines
    TRISA  = %11111111
    TRISB  = 0
    TRISC  = 0
    CMCON  = 7
    ADCON0 = %11000001
    ADCON1 = %10000100
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc * 33 /92
    tb1 = tb0*721
    tb2 = Div32 255
    tb2 = tb2 - 64
    tb0 = tb2/10
    tb1 = tb2//10
    PAUSE 200
    Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC1 tb1,178,"C"
    goto lp
    Gives me a 0 - 100°C scale for adc = 67 to 1023 ...
    so, i suppose it to be " not so bad , but to confirm "
    One more thing ...
    better use
    TRISA  = %11111111
    TRISB  = 0
    TRISC  = 0
    CMCON  = 7
    ADCON0 = %11000001
    ADCON1 = %10000100
    ntc VAR WORD
    tb0 VAR WORD
    tb1 VAR WORD
    tb2 VAR WORD
    PAUSE 700
    LCDOUT $fe,1
    lp:
    ADCIN 1,ntc
    tb0 = ntc * 33 /92
    tb1 = tb0*721
    tb2 = Div32 255
    tb2 = tb2 - 64
    tb0 = tb2/10
    tb1 = tb2//10
    PAUSE 200
    goto lp
    Ok, my problem is largely solved, and if change my PIC, I'll be warn of ADC values. I think my PIC is a special case.
    Thanks everyone.
    Epilog ...
    for general knowledge ... a look at Microchip AN 942 may be valuable ...
