If you are planning to use PBP then you may want to look at supported parts for PBP.
http://melabs.com/includes/compatibility/pbp.pics.htm
Go with an 18F for new projects.
Ok, so I chose the 18f4620, I have a new question though. When you compile your program in Microcode Studio and it tells you in the bottom left corner that your program uses (in my case) 1632 bytes, do I compare that to the chips 64K bytes of flash memory? I'm used to it telling me how many words I've used, not bytes.
here is the datasheet for the chip:
http://ww1.microchip.com/downloads/e...Doc/39626b.pdf
"do I compare that to the chips 64K bytes of flash memory?"
Yes.
