DDS (generating sine waves) with onboard DAC using latest PIC 16F chips?
Results 1 to 40 of 77
    Mar 2009
    Default Re: DDS (generating sine waves) with onboard DAC using latest PIC 16F chips?
    EDIT: Oooh, Hank, I think you're in for some trouble in the long run..... You have your handler defined as ASM yet we're doing a host of "PBP-work" in the handler. If you're not very carefull and know exactly what you're doing that is a very likely cause for trouble and data corruption due what is described above. Either write the handler in ASM or define as it type PBP and include the Re-Enter file.
    EDIT2: Currently it might not be a problem since you're not doing anything in the main loop but as soon as you start doing things there it's going to go havoc.
    Good spot (cut & paste from another program + laziness!) - now changed.
    The frequency is very easy to set though (presently I work out the tuning word value by way of a simple spreadsheet!)
    Higher frequencies look ugly as sin (I even cranked the interrupt rate up - not much better) ...maybe it's just the simple filter I used ....hmm, not sure that PWM is gonna be the solution here (as expected the signal amplitude is related to frequency eg 400hz about 4V peak to peak but 4000hz circa 3.5V peak to peak, it'll be worse with a two pole filter) ...it looks like an R2R ladder is going to be the way forward...damnit!
    Hi Hank,
    There might be also a problem with the code I posted. This is new territory for me as well.
    I think that the PWM is one part of the problem, do try it with a R2R resistor DAC on a port and see what happens?
    However, don't forget how this works.... The lookup table is 256 entries long. At 500Hz output frequency you would need an interrupt rate of 500*256=128kHz to "hit" every entry in the table (thus producing the highest possible quality output). As the frequency goes up more and more of the table entries are skipped, you might "hit" entry 5, 75, 145, 205, 29, 9, 169, 239, 53, 123,193, 7 and so on. Plotting those values and drawing a straight line between them isn't going to produce a very pretty sine-wave.
    I suck at filter desing and analog stuff (too) so I can't help much with the filter desing.
    Mar 2009
    The scoped waveform didn't show the main problem... at higher waveform frequencies there was ripple moving through the waveform (left to right)....I'm thinking it might be a 'beat' frequency relating to the difference between the pwm rate & interrupt rate (or it may be that my filter is just too woeful). Anyway, whilst pwm might be just the ticket for very low frequencies or static (or narrow range) of frequencies...I don't think it's the solution here.
    ok, I can feel an R2R ladder coming on!
    How is your filter constructed?
    Mar 2009
    OP PIN -> 2.2K resistor------------------> scope
    .................................01uf cap
    ...................................Gnd
    ok, I've implemented an R2R ladder - much nicer....but not without issue.
    The waveform is rather nice up to about 1.5khz, but then it starts degrading , this is 3.33khz..
    ok, so that doesn't look too bad (but when you make it larger, it's steppy)
    If I up the interrupt rate things get better, but I can't get the interrupt rate any faster than about 80khz, before I hit a wall.
    Firstly with DTS_INT using 'pbp' ...woeful, can't get the interrupt rate above 20Khz
    Next DTS_INT using 'asm' instead ...I can get the interrupt rate past 80khz before my scope measures a different output frequency to what it should be present.
    there's almost nothing in my interrupt routine....
    DDS:
    ACCUMULATOR = ACCUMULATOR + tuning_word
    Lookup Accumulator.HighBYTE, [$80,$83,$86,$89,$8C,$8F,$92,$95,$98,$9C,$9F,$A2,$A5,$A8,$AB,$AE,$B0,$B3,$B6,$B9,$BC,$BF,$C1,$C4,_
    $C7,$C9,$CC,$CE,$D1,$D3,$D5,$D8,$DA,$DC,$DE,$E0,$E2,$E4,$E6,$E8,$EA,$EC,$ED,$EF,$F0,$F2,$F3,$F5,$F6,$F7,$F8,$F9,$FA,$FB,$FC,$FC, _
    $FD,$FE,$FE,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FE,$FE,$FD,$FC,$FC,$FB,$FA,$F9,$F8,$F7,$F6,$F5,$F3,$F2,$F0,$EF,$ED,$EC, _
    $EA,$E8,$E6,$E4,$E2,$E0,$DE,$DC,$DA,$D8,$D5,$D3,$D1,$CE,$CC,$C9,$C7,$C4,$C1,$BF,$BC,$B9,$B6,$B3,$B0,$AE,$AB,$A8,$A5,$A2,$9F,$9C, _
    $98,$95,$92,$8F,$8C,$89,$86,$83,$7F,$7C,$79,$76,$73,$70,$6D,$6A,$67,$63,$60,$5D,$5A,$57,$54,$51,$4F,$4C,$49,$46,$43,$40,$3E,$3B, _
    $38,$36,$33,$31,$2E,$2C,$2A,$27,$25,$23,$21,$1F,$1D,$1B,$19,$17,$15,$13,$12,$10,$0F,$0D,$0C,$0A,$09,$08,$07,$06,$05,$04,$03,$03, _
    $02,$01,$01,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$01,$02,$03,$03,$04,$05,$06,$07,$08,$09,$0A,$0C,$0D,$0F,$10,$12,$13, _
    $15,$17,$19,$1B,$1D,$1F,$21,$23,$25,$27,$2A,$2C,$2E,$31,$33,$36,$38,$3B,$3E,$40,$43,$46,$49,$4C,$4F,$51,$54,$57,$5A,$5D,$60,$63, _
    $67,$6A,$6D,$70,$73,$76,$79,$7C],PORTC
    @ INT_RETURN
    I'm now realising why everyone has assembly in their interrupts!
    80Khz?
    CD audio has a 44.1khz sample rate.
    If it doesn't sound right at that frequency, the problem probably isn't the interrupt rate, and faster won't help.
    Mar 2009
    80Khz?
    A good point well made Darrel (a case of getting too wrapped in something & forgetting the obvious! ) - need to dabble more, but certainly doubling the interrupt rate made the higher frequency output waveform look a lot less steppy on the scope! I've no output filter on this yet...just the raw R2R ladder output.
    hariuc's Avatar
    hariuc Guest
    Hi to all,
    Hope all r doing well.
    I have recently joined this forum and quit impressed about the DDS discussion.
    I have generated sine wave using PWM of pic16f with fixed frequency. my goal is to generate a sine wave in range of frequency from 1 Hz to 500 Hz with the step of 1 Hz. while doing so i am unable to vary the frequency in step of 1 Hz by changing either PWM frequency or number of samples in sine wave.
    As i am unable to produce a sine wave with step accuracy using PWM. i am thinking to use some other on chip module like DAC to achieve my goal.
    Please give me your valuable suggestions about, what module i should use to get my job done.
    thanks
