Base64
Results 1 to 8 of 8
Thread: Base64
    Sep 2009
    Default Base64
    Has anyone tried to make a BASE64 encoder for email SMTP authentication in pbp?
    I am trying to create e-mail client on the PIC and gsm modem.
    For those who do not know, this is what it is:
    http://en.wikipedia.org/wiki/Base64
    Angry
    yes and this was 3 years ago or so. This forum have a search function, you should try, it's amazingly accurate, fat free and doesn't bite at all.
    http://www.picbasic.co.uk/forum/showthread.php?t=8486&
    Sep 2009
    I tried, but I didn't found it.
    And I could not even find google search forum. I hope not too much trouble for you...
    If you put the keywords "base64 picbasic" in Google, the first thing on the top is the link Steve gave you.
    Magic, isn't it??
    You can do just as Ioannis mentions, or to narrow you search, you can use the picbasic google search located under wiki and useful links, http://www.picbasic.co.uk/forum/cont...-for-the-Forum
    http://www.scalerobotics.com
    Feb 2011
    I and some of my friends had tried to create e-mail client on the PIC and gsm modem some years ago. But we were not successful. I would request Pedja to let me know how he is trying to do it. I would like to thank him in advance for his help.
    Sep 2009
    I'm almost finished. The program is written, but I have not found the time to test it.
    To test an email server, I used putty.
    Here's communications with the server.
    EHLO
    AUTH LOGIN here should be base64 emall  http://www.webpan.com/Customers/Email/base64_conversion.htm
    334 UGFzc3dvcmQ6 '=password
    enter password in base64
    235 Authentication succeeded
    MAIL FROM: <123@123>
    250 OK
    RCPT TO: <1123@123>
    250 Accepted
    DATA
    354 Enter message, ending with "." on a line by itself
    To: <1123@123>
    Subject: Hello
    Date: 17:05:41
    MIME-Version: 1.0
    Content-Type: text/plain; charset=us-ascii
    This is a simple Message
    . 'end of mesage, dot in singl
    250 OK id=1Pch7Q-0003zQ-BX
    First you need to set up gprs conn.
    then
      serout2 tx,84,["AT+CIPSTART=0,",34,"TCP",34,",",34,"mail.123",34,",","26",13,10]
     CALL WAIT_OK
     IF OK=0 THEN GOTO send
     serin2 rx,84,lag,ERR_GPRS,[wait("0, CONNECT OK")]
     serin2 rx,84,lag,err_mail,[wait("220")]
     pause 700 ' wait for comments
     serout2 tx,84,["AT+CIPSEND=0",13,10]
     CALL WAIT_V 'wait for >
     IF OK=0 THEN GOTO ERR_GPRS
     pause 10
     serout2 tx,84,["EHLO",13,10]
     pause 5
     serout2 tx,84,[26]
     CALL WAIT_SEND_OK
    serin2 rx,84,lag,err_mail,[wait("250")]
     pause 700
     serout2 tx,84,["AUTH LOGIN email in base64",13,10]
    etc...
    Base64 in vb6 application, I use to set email, server, time between e mail, and other device parameters.
    With a slightly different message body, you can send attachment.
    EDIT:
    I used the same principle for ftp. Works over a month without a single error
