TRISA, TRISB setting ?
Results 1 to 8 of 8
    Jun 2008
    Varese , Italy
    Default TRISA, TRISB setting ?
    good day,
    I am using the pic 18f452 to acquire some analog signals, to activate some discretes, to read and write ext memory, to interface wuith the serial link and read discretes ( pushbuttons ) and I did not use the TRISA nor TRISB . The system works well.
    I will like to understand the real usage or when the TRISA TRISB need to be used in a picbasic pro programs.
    Thanks for the assistance,
    Ambrogio
    Hi, Ambrogio
    May I suggest you to open your Holy Manual and just read the INPUT and OUTPUT commands pages ... a look to other commands pages will show you that PBP automatically sets inputs/outputs as desired ... or not !
    Jun 2008
    Varese , Italy
    you mean the PBP manual ?
    tnks
    Ambro
    Hi, Ambrogio
    Jun 2008
    Varese , Italy
    I found what you suggested to look_at.
    When a PIC MCU powers-up, all of the pins are set to input. To use a
    pin as an output, the pin or port must be set to an output or a command
    must be used that automatically sets a pin to an output.
    To set a pin or port to an output (or input), set its TRIS register. Setting a
    TRIS bit to 0 makes its corresponding port pin an output. Setting a TRIS
    bit to 1 makes its corresponding port pin an input.
    So, it is not needed to use tris register !
    Am I right ?
    Ambrogio
    Hi, Ambrogio
    Using many of the PBP commands as you are reading setting TRIS is not needed.
    But
    as time goes on and your code becomes more complex TRIS will need set. It will be good to get the habit of string TRIS now... or just wait until the code does not work and remember this.
    One example would be reading/writing to the port.
    Jun 2008
    Varese , Italy
    Does the problem arise if I do : high LED, low LED ... or.. If PB=1 then... If PB=0 then...
    Next: I2C requires a pin to be an output and an input for correct communication: what should I declare in the TRIS reg ?
    Ambrogio
    But
    Hi, Ambrogio
    I' ve taken the good habit ALWAYS to set ALL my Inputs/Outputs with TRIS statements AND aet their respective default level in the first lines of my programs.
    of course, all SFR's and variables too ...
    Whether PBP ( or any other high level language ) does it for me or not ... so, I'm REALLY sure of what will happen. Especially @ Power-up.
    But you can do as you want ... there's no absolute rule !!!
    no automatic input setting here ... sooooo you could read an output state !!!
    I2C is one of those commands that will set the TRIS for you. But like Alain said, you will want to control things at start up. I would set them as an input.
    If you have floating pins set them as out puts.
