Hi folks:
I have a couple big arrays in a program, and I am running out of codespace on the 16F88. I'd like to use EEPROM to store the data vs an array to free up some space, but am unsure of the approach to be taken. I've played with WRITE and READ, but not in a loop that did anything...
An example array is as follows:
1. The variables:
foo.array var byte[34] ' the array that will contain all the data
2. Program:
' get data - read from serial pin data that comes in every second
Serin2 Cpinin,84,1000,nodata,[wait($02,$47), STR foo.array\34]
' Calculate the variables from the array
' read data for temperature which is in hex
SSD4= (foo.array[24]>>4)
SSD3= (foo.array[24] & $f)
SSD2= (foo.array[23]>>4)
SSD1= (foo.array[23] & $f)
Dec_temp=(ssd4*4096)+(ssd3*256)+(ssd2*16)+ssd1 ' convert to decimal
' write out the new data to display
serout2 cpinout, 84,["Temp: ",Dec_temp]
'Loop back and read the next data from serial again..
