Just curious why you need two PICs to do that. A couple people pointed to these types of devices for fast writes. And some of them are good for a 100 trillion read/writes (wonder who had to count those). http://www.ramtron.com/products/nonv...ry/serial.aspx (The 3volt type are even faster)
Ramtron FM24W256
256Kbit Ferroelectric Nonvolatile RAM
• Organized as 32,768 x 8 bits
• High Endurance 100 Trillion (1e14) Read/Writes
• 38 year Data Retention
• NoDelay™ Writes
• Advanced High-Reliability Ferroelectric Process
Fast Two-wire Serial Interface
• Up to 1 MHz Maximum Bus Frequency
• Supports Legacy Timing for 100 kHz & 400 kHz
Low Power Operation
• Wide Voltage Operation 2.7V-5.5V
• 100 uA Active Current (100 kHz)
• 15 uA Standby Current (typ.)
Industry Standard Configuration
• Industrial Temperature -40°C to +85°C
• 8-pin SOIC (-G)
• 8-pin EIAJ SOIC (-EG)
Ordering Information
• FM24W256-G (8-pin "Green"/RoHS SOIC)
• FM24W256-EG (8-pin "Green"/RoHS EIAJ SOIC)
I was planning to use one pic to collect data and populate the memory and then let the other (the one creating the output) keep banging away without having to wait to collect data. I considered looking a the propeller chip to do this, but thought I would try multiple PICs running simultaneously to do the trick. The timing is an issue because I am creating a weather radar simulation that creates weather pattern returns. I have a 5us trigger pulse and then use a dac to create a waveform to represent the return pattern, this repeats every 5000us. Sounds like accessing external memory is going to be too slow.
Thanks.
