I2C with 16F628A mystery
Results 1 to 18 of 18
    May 2009
    Montreal, QC, Canada
    Default I2C with 16F628A mystery
    I am having some difficulty understanding the results I am getting, maybe it is due to something simple but I've been trying to figure it out for the past few hours.
    I am using 16F628A reading and writing to 24LC16 and displaying results on LCD.
    I am also using another application called PonyProg to read/write to my same EEPROM.
    So here is the story;
    I write to the 2416 these values:
    for i2caddr = 0 to 2048 step 16
        i2cwrite d1,d2,i2cdevice,i2caddr,[$01]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr,[$3c]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr,[$08]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr,[$21]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr,[$FF]:pause 10
    next
    then I read back the values and display on the LCD in this way:
    i2caddr = 0
    i2cread d1,d2,i2cdevice,i2caddr,[dat[0],dat[1],dat[2],dat[3],dat[4],dat[5],dat[6],dat[7],dat[8],dat[9],dat[10],dat[11],dat[12],dat[13],dat[14],dat[15]]
    pause 10
    errchk = 0
    for i = 0 to 15
        errchk = errchk + dat[i]
    next
        LCDOUT $FE,1
        lcdout $FE,$80,dec errchk: pause 3000
    Now I am expecting to get errchk = 741 but I get 716.
    I cycled through each value after the addition within the loop and the last number to add up is 230 although the value I wrote was $FF = 255
    Furthermore if I display on the LCD all values I see this:
    1113c3c3c3c3c
    3c888212121cc
    but $cc = 204
    Reading the content of 2416 with PonyProg shows properly:
    01 01 01 3c 3c 3c 3c 3c 3c 08 08 08 21 21 21 ff
    My code is not cleaned up because I was trying different ways but I always get to the same results I tried changing dat[] to word instead of byte but all the data gets messed up on the 2416.
    @ __config _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    clear
    TRISB = 0                   ' Make PORTB all outputs
    CMCON = 7                   ' Disable comparator
    Dat         VAR byte[15]
    I           var byte
    D1          var PORTA.2
    D2          VAR PORTA.3
    I2CAddr     Var byte
    I2CDevice   var byte
    ERRchk      var word
    OK          VAR PORTA.4
    ;NOTOK       var PORTA.5
    ERRStatus   var bit
    LCD_DB4     VAR PORTB.7       ' Set port for 4 bits bus
    LCD_DB5     VAR PORTB.6
    LCD_DB6     VAR PORTB.5
    LCD_DB7     VAR PORTB.4
    LCD_RS      VAR PORTB.0       ' Set RS bit port
    LCD_E       VAR PORTB.1       ' Set Enable bit port
    LCD_Lines     CON 2         ' # of Lines on LCD,  1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS    CON 50        ' Data delay time in us
    LCD_COMMANDUS CON 2000      ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp"    ' Must go after LCD initialization
    Pause 500: LCDOUT $FE,1: pause 250   ' clear screen and relax
    Start:
    i2cdevice =160
    LCDOUT $FE,$80,"Start"
    next
    i2caddr = 0
    pause 10
    errchk = 0
    for i = 0 to 15
    next
        LCDOUT $FE,1
    if errchk = 741 then ERRStatus = 0
    i2caddr = 2032
    pause 10
    Errchk = 0
    for i = 0 to 15
       ; LCDOUT $FE,1
       ; lcdout $FE,$80,dec ERRCHK: pause 2000
    next
    if errchk = 741 and errstatus = 0 then
        high ok
        pause 10000
        low ok
    lcdout $FE,$C0,dec ERRCHK
    LCDOUT $FE,$80,hex dat[0],hex dat[1],hex dat[2],hex dat[3],hex dat[4],hex dat[5],hex dat[6],hex dat[7]
    LCDOUT $FE,$C0,hex dat[8],hex dat[9],hex dat[10],hex dat[11],hex dat[12],hex dat[13],hex dat[14],hex dat[15]
    Thanks for any help.
    Mike
    Dat VAR byte[15]
    must be 16
    </pre>
    May 2009
    Hi Steve,
    Thank you...!
    I tried changing it to 16 and my total is now as expected = 741
    and also showing as FF on LCD.
    But why should it be 16?
    if Dat[0] is working then 0 to 15 = 16 addresses isn't it?
    Mike
    an array that range from 0 to 15 is an array of 16 elements... hence the 16. Facile hein?
    May 2009
    Ok that makes sens.
    Actually I am feeling kind of stupid right now!
    After a glass of wine I will be fine.
    Un gros merci!
    Mike
    Jun 2005
    Surrey, England
    Quote Originally Posted by lilimike View Post
    Ok that makes sens.
    Un gros merci!
    Mike
    BTW you defined I2CAddr as a byte, but treat it as a word (2048) - should be a word.
    Peter
    May 2009
    This is an interesting observation, Thank you.
    I wonder why it still works though!
    Funny how sometimes a programming error is undetected by the compiler and then the program runs with unpredictable results and other times it just works!
    Mike
    Jun 2005
    Surrey, England
    Further investigation has revealed why your checksum still worked.... (sorry for the rather brief earlier reply - it was from my mobile phone!). If we use the following code:
    I2CAddr     Var byte
    Xray        var byte
    Alpha       var byte
    I2CAddr2    var byte
    I2CDevice   var byte
    I2cdevice =160
    I2CAddr2 = 0
        i2cwrite d1,d2,i2cdevice,i2caddr,[$55]
        hserout [hex I2CAddr, " "]
        pause 10
    next
    This reveals that with i2caddr as a byte, the for/next loop assigns the following values to I2CAddr:
    0 10 20 30 40 50 60 70 80 90 A0 B0 C0 D0 E0 F0
    then stops (whereas as a word continues up to 800 as expected).
    So you are actually only writing to a memory address up to F0, but then reading back gives you the correct checksum. However where are you actually writing to memory? - Well the memory assignment by PBP is sequential in alphabetic order, words first then bytes, and the next byte after I2CAddr is in fact I2CDevice in your code, or in my modification, I2CAddr2, as is seen here:
    _Alpha           		EQU	RAM_START + 018h
    _I2CAddr         		EQU	RAM_START + 019h
    _I2CAddr2        		EQU	RAM_START + 01Ah
    _I2CDevice       		EQU	RAM_START + 01Bh
    _Xray            		EQU	RAM_START + 01Ch
    Now the PBP manual states "The Address size sent (byte or word) is determined by the size of the variable that is used. If a byte-sized variable is used for the Address, an 8-bit address is sent. If a word-sized variable is used, a 16-bit address is sent. Be sure to use the proper sized variable for the device you wish to communicate with."
    I suspect this is in fact not correct and looking at the assembler code that PBP generates, in fact I2CWRITE seems to send a word, using I2CAddr, I2CAddr2 as the (word) address in my example, or the case of your code, actually I2CAddr, I2CDevice (=$A0) which is I suspect somewhere other than you intended in memory!
    Peter
    May 2009
    Thank you Peter,
    I understand the first part of your response but not sure about the second part:
    I will continue to read it over and over, some times it takes me a few times to understand.
    Now again I am running into some mystery and I wish I could understand better...
    If I run this code:
    i2cdevice =$A0
        i2cwrite d1,d2,i2cdevice,i2caddr,[$ff]:pause 10
    next
    Then I read the EPROM with Ponyprog and observed everything as expected.
    Then I rewrote my code by changing:
    to
    for i2caddr = 0 to 1024 step 16
    and the 3 first line I replaced $01 by $ff.
    I was expecting to see half of the memory filled with my changes but it got filled all the way to address $7FF:
    The more I test the more I get confused!
    Mike
    Jun 2005
    Surrey, England
    Actually I was wrong about the Addressing - I hadn't noticed you were using a 24C16 - I normally use larger chips - in fact the 24C16 needs a byte for the address. Unfortunately the addressing you require is a little more complex - the 2K memory is organised in 8 x 256 byte blocks and the A10, A9, A8 are conveyed as the lower 3,2,1 bits of the Control byte, and A7-0 in the Address byte - a rewrite of your addressing is needed!
    Control Byte: 1010XXX0 where XXX are the high order 3 bits of the address
    Address Byte: XXXXXXXX = A7-0
    You will need to create the Control byte for each successive write. Get back to me if you need any more help.
    Peter
    May 2009
    Ok so maybe I need more help.
    There is obviously something I don't understand.
    Looking at the 24CL16 datasheet:
    Based on this I changed the address to word and my understanding is:
    Control byte = 1010 000 0 = $A0
    I want to write $aa at address $400 so I wrote this code:
    i2cdevice =$A0
    i2caddr = $400
        i2cwrite d1,d2,i2cdevice,i2caddr,[$aa]:pause 10
    I was expecting to see only address $400 showing value $aa but this is the result:
    the value $aa is now showing at address $004 and at every next 16 locations all the way to 2048.
    Mike
    Jun 2005
    Surrey, England
    I suggest you use a data array to send your bytes, and then you need to construct the ControlByte and address as in this example:
    Dat         VAR byte[16]
    i           var word
    j           var Byte
    SDA         var PORTA.2
    SCL         VAR PORTA.3
    CntrB       var Byte
    Addr        var byte
        for i = 0 to 15
            lookup i, [$01,$01,$01,$3c,$3c,$3c,$3c,$3c,$3c,$08,$08,$08,$21,$21,$21,$FF], j
            Dat[i] = j
        next
        for i = 0 to $7F0 step 16  'End at 2048-16 = $7F0
            CntrB = %10100000
            CntrB.3 = i.10
            CntrB.2 = i.9
            CntrB.1 = i.8
            Addr = i.lowbyte
            i2cwrite SDA,SCL,CntrB,Addr,[str Dat\16]
            pause 10
        next
    Peter
    May 2009
    ok I have created a new file and inserted your code with some of my code required for access to the EEPROM but when I run this code nothing gets written to the chip.
    This is the complete code:
    clear
    TRISB = %00001000
    CMCON = 7                   ; Disable comparator
    OPTION_REG = 0
    Activate    var PORTB.2     ; 1 = access eeprom / 0 = normal operation
    GO          VAR PORTB.3     ; Start switch
    OK          VAR PORTB.4     ; Green LED
    NOTOK       var PORTB.5     ; Red LED
    Dat         VAR byte[16]
    i           var word
    j           var Byte
    SDA         var PORTA.2
    SCL         VAR PORTA.3
    CntrB       var Byte
    Addr        var byte
    activate = 1
        for i = 0 to 15
            Dat[i] = j
        next
            CntrB = %10100000
            CntrB.3 = i.10
            CntrB.2 = i.9
            CntrB.1 = i.8
            Addr = i.lowbyte
            pause 10
        next
    activate = 0
    I've been struggling with this almost nonstop for a couple of days and I believe that either I think I am working with a 24LC16 chip and it is not or I have a hardware issue. The EEPROM chip is not visually accessible but my PonyProg application is detecting it as"2416" - Device type "2402-16"
    This is my hardware and I ruled out any discrepancies between my drawing and actual PCB:
    Thanks for your time,
    Mike
    May 2009
    sorry, Your code did write to the chip, what I did was to zero out the complete memory using this code:
    I2CAddr = $0
    I2CDevice = $A0
        i2cwrite d1,d2,i2cdevice,i2caddr,[0]:i2caddr = i2caddr + 1:pause 10
    Then I ran your code (as previous post) and I see that it wrote value FF on every 16th location from memory 0 to 2032 as such:
    Mike
    Jun 2005
    Surrey, England
    I am not familiar with PonyProg, are you using the SI-Prog baseboard hardware and the I²CBus eeprom adapter - I note that the adaptor does not have any pullup resistors on SDA and SCL and the baseboard does not provide these either - You have implemented the R2/R3 4K7 pullups shown on your schematic, havent you?? I have had many frustrating experiences with I2C Memory chips instantly solved by a pair of pull up resistors.
    Failing this, I dont understand why the memory chip is visually inaccessible, but these results suggest you may not be dealing with a 24C16 chip - other chips may need different addressing.
    May 2009
    The chip is enclosed into a sealed device and the only thing exposed are the 4 pads for power and I2C. With trial and error... and trial and error over trial and error I managed to get what I need working. I know my program doesn't have much style but for now it does what it is supposed to do.
    The process of my program is as follow:
    When I press the switch I need to read address $04 and if it is > 5 it will flash the OK LED the number of the value found and then quit. If it is not greater than 5 then I want to set values $01,$01,$01,$3c,$3c,$3c,$3c,$3c,$3c,$08,$08,$08,$2 1,$21,$21,$FF all over.
    I don't understand why I just write once and the chip gets updated all over but it works.
    This device is hooked up to another device that will update the chip daily by setting address $04, $05, $06 to -1 each day.
    I am definitely going to order some chips and test on breadboard until I get a good understanding of this.
    In the mean time this is my working code:
    clear
    TRISB = %00001000
    OPTION_REG = 0
    SWSTAT      var byte
    Dat         VAR byte
    I           var byte
    I2CAddr     Var word
    I2CDevice   var byte
    D1          var PORTA.2     ; Cartrige white wire
    D2          VAR PORTA.3     ; Cartrage blue wire
    Activate    var PORTB.2     ; select between reset=1 normal=0
    activate = 0                ; Normal operation
    ok = 0                      ; Green LED off
    notok = 0                   ; Red LED off
    goto swstatus
    Start:
    ;--------make sure reset is needed-----------
    activate = 1                ; get ready to reset
    swstat = 0                  ; reset switch debounce
    pause 50                    ; give time or relay contact
    i2cdevice = $A1
    i2caddr = 3
    i2cread d1,d2,i2cdevice,i2caddr.lowbyte,[dat]
    pause 10
    if dat > 5 then
        for I = 1 to dat
            ok=1: pause 500:ok = 0:pause 500
        next
        activate = 0                    ;------Resume normal operation
        goto SwStatus
        ok = 1: pause 3000: ok = 0  ; Green LED on for 3 seconds
        pause 5000
        I2CAddr = $0
        I2CDevice = $A0
        i2cwrite d1,d2,i2cdevice,i2caddr.lowbyte,[$01]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr.lowbyte,[$3c]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr.lowbyte,[$08]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr.lowbyte,[$21]:i2caddr = i2caddr + 1:pause 10
        i2cwrite d1,d2,i2cdevice,i2caddr.lowbyte,[$ff]:pause 10
    ;---------------------make sure data was written-------------------------
        i2cdevice = $A1
        i2caddr = 4
        pause 10
        if dat = $3c then           ;------all is good, flash green LED
            for I = 1 to 10
                toggle ok
            next
            ok = 0
        else                        ;------Something wrong, flash red LED
            for I = 1 to 10
                toggle notok
            next
            notok = 0
    SwStatus:
    if go = 0 then debounce
    swstat = 0
    goto SWstatus
    debounce:
    swstat = swstat + 1
    pause 10
    if swstat = 150 then start
    goto swstatus
    Thank you for your help.
    Mike
    May 2009
    Hi Dave,
    I went a little too fast in my project, when I thought my circuit was good I built the PCB and dismantled my breadboard and its only after I saw this.
    But thanks for the info
    Mike
