For home made pcb's look also at http://www.pulsarprofx.com/pcbfx/main_site/pages/
I liked very much the idea of having etching with a sponge and a few drops of etchant fluid.
@Dave, I would love to see pics of your mill!Also, mill size, speed and feed. Have you tried cutting any solder mask's? I saw someone doing that on you tube with some .005 brass I think. Seems like I remember them holding it down with 3M or some other spray glue.
@Ioannis, That is a GREAT link! I think I have read the entire site, and I must say, it looks like a wonderful technique. Still unsure on solder mask and the via's sound a bit cumbersome. but for prototyping, sounds like fun.
@Darrel, Thanks for jumping in and carrying the flag for VSM! Without the advanced sim stuff, are you able to watch outputs like on a scope? So being able to compare timing between signals and such?
-Bert
Oh yeah, lots of test equipment.
4-ch. O-Scope (DSO)
32-ch. Logic analyzer
Frequency counter/timer
I2C debugger
SPI debugger
Voltmeter
Ammeter
Pattern Generator
Signal Generator
Virtual Terminal
And you can have multiples of each one. Try putting 4 O-scopes on your workbench.
More test equipment than I could ever afford in real life.
RS232 ports connect to real COM ports.
Sound devices use the PC speakers.
Virtual ATA hard drives.
Stepper Motors
Servo Motors
LCDs
GLCDs
Switches, keypads
LED's, LED matrix
RTC's, EEPROM's, 7400 TTL series, 4000 CMOS series chips.
And if you're old enough ... Thermionic Valves (Tubes)
You can run multiple PIC's, each with a different program, at the same time.
It's just Waaaaay Toooo Coool!
I'm old enough to know these are the glowing orange things that used to make the TV have to "warm up" before watching!
Darrel Thanks for helping with this decision. I am sure I am going to pull the trigger for this. My "bench space" is low, So this is a great idea!!
-Bert
I'm with Daryl on the sim... I've been using the vsm for several years, and love it. The advanced stuff is more for calculating noise in audio ckts and such. Using Isis has cut down on development time a lot, and I can't imagine what Mr. E is complaining about. Their models are very accurate--sometimes MORE accurate than the hardware. (i.e. designed with no batch-specific errata.)
I used Eagle prior to switching to Ares. I switched because I figured it'd be nice to have just one cad package, and Eagle had a few things that really irked me. Well, Eagle fixed those things right when I bought Ares, and I'd have stayed with it had I known more.
When you sim a PIC, you typically don't sim the full ckt--you put in primitives, and stuff like that so it will sim at full speed. Full analog slows it down a LOT, so you end up with two schematics (or one that's a lot bigger and messier, with some excluded from sim and some excluded from pcb) doing it this way. As far as layout goes, Ares isn't quite up to the power of Eagle. They both have annoying quirks, but Eagle is a bit more powerful...although Ares is slowly catching up, and it is nice having just one forum to read. Oh, yeah... Eagle has a LOT more part libraries, too, but they are significantly easier to make in Ares, and a lot easier to edit too.
So, now that I have it, I'm not about to go back to Eagle...but had I known then what I know now I'd have stuck with Eagle. I like its precision and power, but it's harder to learn.
That's my 2c.
My mill is a Fireball V90. I replaced the stock bed with 1/2 inch aluminum plate milled flat to match the gantry. I run between 15 and 30 inch per minute depending on the part. Using a 30 degree point I can do 44 pin TQFP parts on half ounce copper.
I do not have any pictures with me.
