I'm having a problem with reading two analog inputs. The first channel (GPIO.0) works well but the issue is that the next channel reads identically even though the voltage going into the pin is clearly different.
I must be missing something simple, I think that what I am trying to do is quite basic. I've looked at the PicBasic Pro manual, the datasheet and searched the forum. I did see that someone had a similar problem but the solution was not effective for me.
The wiring has been checked over many times, I am confident that the error is in the code.
The intention is to read the two axis and the button of a mini joystick and send the data serially to another uC.
Rich HCode:@ DEVICE PIC12F683, MCLR_OFF @ DEVICE PIC12F683, INTRC_OSC_NOCLKOUT @ DEVICE PIC12F683, WDT_OFF @ DEVICE PIC12F683, BOD_ON @ DEVICE PIC12F683, PWRT_ON '------------------------------------------------------------------------------- DEFINE OSC 8 Define ADC_BITS 8 ' Set number of bits in result Define ADC_CLOCK 3 ' Set clock source (3=rc) Define ADC_SAMPLEUS 50 ' Set sampling time in uS define CHAR_PACING 1000 OSCCON = %01110001 ' internal oscillator at 4 MHZ CMCON0 = 0 ' Comparators off ANSEL = %00000011 ' Set 0, 1, analog WPU = 0 ' Internal pull-ups = off GPIO = %00000000 ' All outputs = 0 on boot TRISIO = %00011111 ' GPIO.0,1,2,3,4 input, GPIO.5 output joyY var GPIO.0 joyX var GPIO.1 joyBtn var GPIO.2 Sout var GPIO.5 AD var byte X var byte Y var byte Btn var byte B var bit Main: adcin joyX, AD X = AD AD = 0 pause 1 adcin joyY, AD Y = AD AD = 0 B = joyBtn if B then Btn = Btn + 1 else Btn = 0 endif if Btn > 100 then Btn = 100 serout Sout, 2, ["cmd", X, Y, Btn, 128, 128] goto Main end
Just kidding
