Ok, Thanks. I will go with the triac then. I'm using BTA already so thats good.
I did think about using a relay but I've used those in the past for the pump motor and they cause all nearby PICs to reset (I had a post on here a few years ago about it). The solution was to use triacs. I've used diodes in the past on the low voltage side of relays to stop current flowing backwards. Maybe something like that on the high voltage side would fix the problem but I would rather use a triac instead.
