Configuration? Fuse? question
Results 1 to 5 of 5
    Dec 2010
    Melbourne Australia
    Default Configuration? Fuse? question
    I have a PIC18F14K50 and ...13K50 variants and I need to configure the Master Clear MCLRE off (ie. disabled). It's bit 7 in the Config3H register. What's the easiest way to do this and does anyone have any advice or links to provide me with clearer understanding of the formats or protocols of how to set these registers?
    Thanks for any help,
    Troy.
    Quote Originally Posted by rocket_troy View Post
    Hello Troy,
    Here is a link to what I think is the best way to set your config bits. http://www.picbasic.co.uk/forum/cont...o-your-Program
    Check out 3.b
    This allows you to set them in your code like this:
    asm
            __CONFIG    _CONFIG1L, _CPUDIV_NOCLKDIV_1L & _USBDIV_OFF_1L
            __CONFIG    _CONFIG1H, _FOSC_HS_1H & _PLLEN_OFF_1H & _PCLKEN_ON_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG2H, _WDTEN_ON_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _BBSIZ_OFF_4L & _XINST_OFF_4L
    endasm
    You will need to first comment them out of the C:/PBP/18F14K50.inc file. Then you will need to figure out what they all are from the data sheet and the C:\Program Files\Microchip\MPASM Suite\P18F14K50.INC file, and see what your options are:
    Here is just a listing of what you will see when you read the P18F14K50.INC file. Notice that mclear off is in config3h.
    ;----- CONFIG1L Options --------------------------------------------------
    _CPUDIV_NOCLKDIV_1L  EQU  H'E7'    ; No CPU System Clock divide
    _CPUDIV_CLKDIV2_1L   EQU  H'EF'    ; CPU System Clock divided by 2
    _CPUDIV_CLKDIV3_1L   EQU  H'F7'    ; CPU System Clock divided by 3
    _CPUDIV_CLKDIV4_1L   EQU  H'FF'    ; CPU System Clock divided by 4
    _USBDIV_OFF_1L       EQU  H'DF'    ; USB clock comes directly from the OSC1/OSC2 oscillator block; no divide
    _USBDIV_ON_1L        EQU  H'FF'    ; USB clock comes from the OSC1/OSC2 divided by 2
    ;----- CONFIG1H Options --------------------------------------------------
    _FOSC_LP_1H          EQU  H'F0'    ; LP oscillator
    _FOSC_XT_1H          EQU  H'F1'    ; XT oscillator
    _FOSC_HS_1H          EQU  H'F2'    ; HS oscillator
    _FOSC_ERCCLKOUT_1H   EQU  H'F3'    ; External RC oscillator, CLKOUT function on OSC2
    _FOSC_ECCLKOUTH_1H   EQU  H'F4'    ; EC, CLKOUT function on OSC2 (high)
    _FOSC_ECH_1H         EQU  H'F5'    ; EC (high)
    _FOSC_ERC_1H         EQU  H'F7'    ; External RC oscillator
    _FOSC_IRC_1H         EQU  H'F8'    ; Internal RC oscillator
    _FOSC_IRCCLKOUT_1H   EQU  H'F9'    ; Internal RC oscillator, CLKOUT function on OSC2
    _FOSC_ECCLKOUTM_1H   EQU  H'FA'    ; EC, CLKOUT function on OSC2 (medium)
    _FOSC_ECM_1H         EQU  H'FB'    ; EC (medium)
    _FOSC_ECCLKOUTL_1H   EQU  H'FC'    ; EC, CLKOUT function on OSC2 (low)
    _FOSC_ECL_1H         EQU  H'FD'    ; EC (low)
    _PLLEN_OFF_1H        EQU  H'EF'    ; PLL is under software control
    _PLLEN_ON_1H         EQU  H'FF'    ; Oscillator multiplied by 4
    _PCLKEN_OFF_1H       EQU  H'DF'    ; Primary clock is under software control
    _PCLKEN_ON_1H        EQU  H'FF'    ; Primary clock enabled
    _FCMEN_OFF_1H        EQU  H'BF'    ; Fail-Safe Clock Monitor disabled
    _FCMEN_ON_1H         EQU  H'FF'    ; Fail-Safe Clock Monitor enabled
    _IESO_OFF_1H         EQU  H'7F'    ; Oscillator Switchover mode disabled
    _IESO_ON_1H          EQU  H'FF'    ; Oscillator Switchover mode enabled
    ;----- CONFIG2L Options --------------------------------------------------
    _PWRTEN_ON_2L        EQU  H'FE'    ; PWRT enabled
    _PWRTEN_OFF_2L       EQU  H'FF'    ; PWRT disabled
    _BOREN_OFF_2L        EQU  H'F9'    ; Brown-out Reset disabled in hardware and software
    _BOREN_ON_2L         EQU  H'FB'    ; Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    _BOREN_NOSLP_2L      EQU  H'FD'    ; Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    _BOREN_SBORDIS_2L    EQU  H'FF'    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    _BORV_30_2L          EQU  H'E7'    ; VBOR set to 3.0 V nominal
    _BORV_27_2L          EQU  H'EF'    ; VBOR set to 2.7 V nominal
    _BORV_22_2L          EQU  H'F7'    ; VBOR set to 2.2 V nominal
    _BORV_19_2L          EQU  H'FF'    ; VBOR set to 1.9 V nominal
    ;----- CONFIG2H Options --------------------------------------------------
    _WDTEN_OFF_2H        EQU  H'FE'    ; WDT is controlled by SWDTEN bit of the WDTCON register
    _WDTEN_ON_2H         EQU  H'FF'    ; WDT is always enabled. SWDTEN bit has no effect.
    _WDTPS_1_2H          EQU  H'E1'    ; 1:1
    _WDTPS_2_2H          EQU  H'E3'    ; 1:2
    _WDTPS_4_2H          EQU  H'E5'    ; 1:4
    _WDTPS_8_2H          EQU  H'E7'    ; 1:8
    _WDTPS_16_2H         EQU  H'E9'    ; 1:16
    _WDTPS_32_2H         EQU  H'EB'    ; 1:32
    _WDTPS_64_2H         EQU  H'ED'    ; 1:64
    _WDTPS_128_2H        EQU  H'EF'    ; 1:128
    _WDTPS_256_2H        EQU  H'F1'    ; 1:256
    _WDTPS_512_2H        EQU  H'F3'    ; 1:512
    _WDTPS_1024_2H       EQU  H'F5'    ; 1:1024
    _WDTPS_2048_2H       EQU  H'F7'    ; 1:2048
    _WDTPS_4096_2H       EQU  H'F9'    ; 1:4096
    _WDTPS_8192_2H       EQU  H'FB'    ; 1:8192
    _WDTPS_16384_2H      EQU  H'FD'    ; 1:16384
    _WDTPS_32768_2H      EQU  H'FF'    ; 1:32768
    ;----- CONFIG3H Options --------------------------------------------------
    _HFOFST_OFF_3H       EQU  H'F7'    ; The system clock is held off until the HFINTOSC is stable.
    _HFOFST_ON_3H        EQU  H'FF'    ; HFINTOSC starts clocking the CPU without waiting for the oscillator to stablize.
    _MCLRE_OFF_3H        EQU  H'7F'    ; RA3 input pin enabled; MCLR disabled
    _MCLRE_ON_3H         EQU  H'FF'    ; MCLR pin enabled; RA3 input pin disabled
    ;----- CONFIG4L Options --------------------------------------------------
    _STVREN_OFF_4L       EQU  H'FE'    ; Stack full/underflow will not cause Reset
    _STVREN_ON_4L        EQU  H'FF'    ; Stack full/underflow will cause Reset
    _LVP_OFF_4L          EQU  H'FB'    ; Single-Supply ICSP disabled
    _LVP_ON_4L           EQU  H'FF'    ; Single-Supply ICSP enabled
    _BBSIZ_OFF_4L        EQU  H'F7'    ; 1kW boot block size
    _BBSIZ_ON_4L         EQU  H'FF'    ; 2kW boot block size
    _XINST_OFF_4L        EQU  H'BF'    ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    _XINST_ON_4L         EQU  H'FF'    ; Instruction set extension and Indexed Addressing mode enabled
    _DEBUG_ON_4L         EQU  H'7F'    ; Background debugger enabled, RA0 and RA1 are dedicated to In-Circuit Debug
    _DEBUG_OFF_4L        EQU  H'FF'    ; Background debugger disabled, RA0 and RA1 configured as general purpose I/O pins
    At the bottom of the file you will see the Mclear off setting. Add this to config3h. But since config3h isn't currently in your configs, you would have to add a config3h line, like this:
    asm
            __CONFIG    _CONFIG3H, _MCLRE_OFF_3H
    endasm
    http://www.scalerobotics.com
    Dec 2010
    Melbourne Australia
    Awesome reply scalerobotics! That pretty much perfectly answers my question.
    Thanks a bunch!
    Troy.
    Dec 2010
    Melbourne Australia
    Ok, one more quick one:
    Because I only need the MCLRE disabled for this particular program ie I need all the I/O pins I can get; can I just add the code:
    asm
    endasm
    to my program an leave the rest of the configuration settings uncommented in the INC file? This appears to work fine, but I'm just curious whether it's acceptable coding practice or if I likely to expect any nasty surprises from doing that?
    Troy.
    That works, but you have to be a little careful to remember you have configs in two places. You can't have a config3h with some config3h settings in one, and some config3h's in another. Each config line has to be complete in either place, if that makes any sense.
    But it won't muck anything up doing it as you say.
