Port pin variables
Results 1 to 4 of 4
    Dec 2009
    Warrenton Mo
    Default Port pin variables
    Why does this not work in PicBasic Pro?? I'm using a Pic16f870
    for j=0 to 7
    portb.j=1
    portb.j=0
    next j
    also,
    high portb.j
    does not work
    I get a "Bad Variable Modifier" error at each portb program line
    thanks
    Bombay, India
    Dec 2009
    Warrenton Mo
    Default port variables
    this will compile ok....portb[x] and portb(x) compiles ok too, but it does nothing to activate the port.
    So I guess the question is, how do you use a variable on a port?
    May 2008
    Italy
    Try this way, it will compile and work as well.
    for j=0 to 7
    portb0.[j]=1
    portb0.[j]=0
    next j
    Cheers
    Al.
