Pentax IR Remote
Results 1 to 24 of 24
    Nifty project. Could even use a serial LCD and have a boat-load of options with a menu.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Speaking of intervalometers, did you see the one at http://www.doc-diy.net/photo/hdr-jack/#thecircuit ?
    It uses an atmel and is meant for a Canon, but the design is ingenious.
    Or this: http://cms.diodenring.de/en/electron...tervalltimerv2 ; based on 10F222, works with Canon, Nikon & the newer Pentaxs.
    Planning to build one for my Canon 500D...
    Anand
    Feb 2005
    Anand
    I started with a Canon A570is and CHDK but wanted to use the DSLR for its many advantages, built the diodenring timelapse but my brand new pentax K-x does not have the 2.5mm jack as my previous pentax K-100, stupid me I realized this AFTER building it so the only choice left was to build it using the IR sensor. Crossed many mails with Achim (from diodenring) he is a helpfull guy.
    Regarding the HDR-jack I think this can also be implemented via IR, but not looked into it yet.
    Regarding the program in this thread, I know the timing loop at the begining can be improved using a better way to count time. I could use some help there
    Pablo
    Quote Originally Posted by peu View Post
    Darrel has some great interrupt include files. It makes it pretty easy to do some great things with interrupts, and they can be very efficient as well. Here is a link to a timer example of his. http://darreltaylor.com/DT_INTS-14/elapsed.html
    http://www.scalerobotics.com
    Feb 2005
    interesting, never looked deeply into them, now that I did I have some warnings at compile time, maybe you can help me
    PIC12F683
    pbp 2.60b
    latest mapsm from MPLAB IDE v8.63
    Downloaded ReEnterPBP.bas and DT_INTS-14.bas from Darrel Site and placed at pbpw folder
    And Im trying the example you linked (http://darreltaylor.com/DT_INTS-14/elapsed.html)
    this example requires Elapsed_INT.bas which I found in this thread: http://www.picbasic.co.uk/forum/show...7473#post17473 also placed it at pbpw folder. Is this the current version?
    when I compile the example (using MPASM from microcodestudio) I get these errors:
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 2934 : Invalid RAM location specified.
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 2939 : Invalid RAM location specified.
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 3059 : Invalid RAM location specified.
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 3075 : Invalid RAM location specified.
    What Im doing wrong?
    Feb 2005
    the problem was the LCDOUT, doh! back to learning this interesting interrupt stuff
    Feb 2005
    Added the timer as suggested and it works! BUT, now I lost two things and I don't know why:
    1) the led thats supposed to flash once a second inside the time counting loop only flashes once.
    2) When outside the timelapse function in the previous version if I left the button pressed the camera shooted continuously, now it shots one time per press
    As a BONUS I translated all the comments to English
    '*  Name    : pentax.BAS                                        *
    '*  Author  : PEU based on examples from www.rentron.com        *
    '*  Notice  : Copyleft (c) 2011                                 *
    '*          : No Rights Reserved on derived work                *
    '*  Date    : 05-ENE-11                                         *
    '*  Version : 1.01                                               *
    '*  Notes   : pablou at gmail dot com                           *
    @ #define IRTX GPIO  ; Define port to use for IR out
    @ #define PIN 2      ; Define port pin to use for IR out
    ' 12F683.INC at picbasic folder has this defined already for MPASM use
    ' __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_ON
    '@ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_on
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines  by Darrel Taylor
      GPIO = 0
      TRISIO.2 = 0      ' LED IR
      TRISIO.1 = 0      ' Red LED
      TRISIO.5 = 1      ' Normal open pushbutton (w/ pulldown)
      CMCON0   = 7      ' Comparators disabled
      ANSEL = 0         ' A/D disabled
    '  GIE       VAR INTCON.7  ' Global interrupt enable 1=ON, 0=OFF
      GPIE      VAR INTCON.3  ' Port change interrupt enable 1=ON, 0=OFF
      GPIF      VAR INTCON.0  ' Port Change Interrupt Flag bit
      Cycles    VAR BYTE    ' Number of carrier cycles
      ContaSec  var word    ' Seconds Counter
      TLFlag    var byte    ' Timelapse counter programmed?
      IRLED     var GPIO.2  ' alias LED IR
      LED       var GPIO.1  ' alias red LED
      BOTON     var GPIO.5  ' pushbutton
      GIE = 0            ' Disable global ints
      GPIE = 1           ' Enable port change int
      IOC.5 = 0          ' Int-on-change for GPIO.5 disbled
      PAUSE 100          ' little pause to settle the processor after cold start
    GOTO OverASM     ' jump over ASM routines
    ' Generate "Cycles" number of ~38.4kHz pulses   Bruce at www.rentron.com
    _Pulse38
       bcf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bsf IRTX,PIN     ; 1uS, LED=on
       nop              ; + 1uS = 10uS
       decfsz _Cycles,f ; + 1uS = 11S
       goto _Pulse38    ; + 2uS = 13uS
       return           ; Return to caller
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    OverASM:    ' END of ASM routines
    contasec=0
    tlflag=0
    ' New timer
    GOSUB ResetTime           ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer          ' Start the Elapsed Timer
    while boton = 1           ' Loops while the button is pressed
            if SecondsChanged = 1 then 'if the seconds changed flash the red led
            high led
            pause 50
            low led
            SecondsChanged = 0      ' set flag back to 0
        tlflag=1                    ' This flags lets me know if the timer was used
    wend
    contasec = Seconds + (Minutes * 60) ' Total time elapsed
    gosub StopTimer
    'Loop del TimeLapse
    if tlflag = 1 then              ' if the timer was used continue
        while boton = 0
            sleep contasec  ' sleep programmed time
            gosub trigger   ' trigger
            high led        ' red LED on
            pause 50        ' little pause
            low led         ' red LED off
        wend
    ' Timelapse ended because the button was pushed
        for contasec = 1 to 15  ' flash red LED to let the user know
            high led
            low led
        next
      IOC.5 = 1             ' Int-on-change for GPIO.5 enabled
      GPIO = 0
      Main:                 ' main Loop
        sleep              ; Sleep
       endasm
        while boton=0       ' wait for button push
        wend
        GPIF = 0            ' Clear port change interrupt flag
        pause 50
        pause 200           ' debounce
      GOTO Main
    Trigger:                ' PENTAX pulse train
      Cycles = 255
      CALL Pulse38
      Cycles = 239
      CALL Pulse38
      pauseus 3000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 5000              ' end PENTAX pulse train
      END                       ' Fin   :)
