Manipulating keypad presses
Results 1 to 10 of 10
    Oct 2008
    Default Manipulating keypad presses
    Hello:
    I am scanning a keyad and am receiving and converting the rows and columns to numbers. I am wanting to display the numbers from 0 to 360 on an LCD. It is working as I am using a for next loop to put the key presses into an array. I then multiply the first one by a hundred and so on. But, if I only enter a 2 digit number I have to lead it with a zero, Is there and easier way?
    Let me clarify this a little: I actually want to save say the number 320 in a variable after getting it from a keypad one press at a time and use it to control PWM cycles.
    Thanks, Don
    Not sure to follow you but let's see.
    ' Pseudo, for entertainement only or you'll be changed to a pumpkin at midnight
    Number=0
    Duty=0
    DoIt:
    LCDOUT $FE,1,"Number=",dec number Call KeyPad Routine IF KeyPad Scan routine Return a valid single decimal number entry Then
    Number = (Number *10) + KeyPadValue ' ' Some test to make sure you're in the max duty range ' GOTO DoIt ENDIF
    If Number !=Duty then
    Duty=Number HPWM 1,freq, Number endif
    GOTO DoIt
    Oct 2008
    Mister_E
    Actually I am using your keypad scan routine.
    I am using a
    for x = 1 to 3
    gosub getkey
    array[x] = keypress
    next x
    total = array[x]*100 + array[x]*10 + array[x]
    But I have to make 3 entries in the array to satisfy the for next loop. So I have to use a leading zero if I enter anything less than 100. It works fine its just a pain.
    No you don't need, read my example above again, there's this IF THEN line after the Keypad reading...
    </pre>
    Oct 2008
    Steve,
    I guess I am still a little confused .
    If I go get a keypress and I just pushed 3 for example. How is that moved three decimal places (multiplied by a 100) and then added to the next keypress which must be moved over 2 places?
    I will study it some more but I am not "seeing" it yet.
    Thanks for taking the time.
    Don
    How many key do you have on your Keypad? any left to be used as "enter" key?
    Oct 2008
    I have 16 keys. I am using "E" or I think #14 as enter now for another routine.
    A small hint
    if keypress<=9 then
    Number=(Number*10)+KeyPress GOTO DoIt Endif
