Timer issue
Results 1 to 13 of 13
Thread: Timer issue
    OK, after some tweaking, and using ASM as TYPE (Don't know why yet), is getting correct results up to a reload value of around 180.
    The changes to get close are:
    @ INT_DISABLE TMR0_INT
        TMR0=TMR0+180
        toggle pwm1
    @ INT_ENABLE TMR0_INT
    By adding the value,we have more precise control of the reload value.
    But not close to my target of 25usec
    Only guessing here, but I think Darrel ment the ASM type when there is ASM code in the ISR. I have noticed better accuracy with timers just by changing the type though.
    Now that I read this page again about the underscore, I may be doing something wrong. http://darreltaylor.com/DT_INTS-14/asm_ints.html
    Hmmm. Always something interesting..
    There are some shadows on the DT-INTs routines as there is no Manual. I am willing to help writing a manual document whenever Darrel can provide more insides.
    But for the moment the ASM idea seem to get closer to the target.
    Check the fine print at the bottom of the following
    http://darreltaylor.com/DT_INTS-14/kudos.html
    Fine print... There is always fine print....
    Hey Steve, Good to read you again!!!
    Hehe, you'll probably see me a bit more in 2011. Who knows?
    Steve : 2 points
    Dave : 1 point
    Simply Using MPSIM could have clearly shown what was going on.
    Interrupt duration always must be smaller than the period of the timer.
    Obvious, when it is told like this ...
    Sims sucks
