Timer issue
Results 1 to 13 of 13
Thread: Timer issue
    Default Timer issue
    I am not getting the time I expect from the following Interrupt Driven timer.
    Controller is 16F887,internal OSC at 8MHz, expected interrupt every 25usec and I get every 101usec.
    If I change the reload value to 63, the expected interrupt is 100usec and I get 146usec.
    A check on the IntOSC with Clock out on RA6 prooves that the Clock is correct @ 2MHz (8MHz/4).
    I tested also with the Timer2 w/o pre-post scalers with exactly the same results.
    Here is the test code that is making me nervous:
    DEFINE OSC 8
    OSCCON = %01110001 'SET SYSTEM CLOCK SWITCH BIT
    @Line1 = _DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON
    @Line2 = _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
    @ __CONFIG _CONFIG1, Line1 & Line2
    @ __CONFIG _CONFIG2, _WRT_HALF & _BOR40V
    PORTA=0:PORTB=0:PORTC=0:PORTD=0:PORTE=0
    TRISA=%00101101
    TRISB=%00000000
    TRISC=%10000000
    TRISD=%00000011
    TRISE=%00000000
    OPTION_REG=00001111
    WPUB = %00111111
    ADCON0 = %11000001
    ADCON1 = %00000000	'Set PORTA/E analog/digital, right justify result
    ANSEL  = %00101101  'lower port A as Analog input
    ANSELH = %00000000  'all others Digital inputs
    DEFINE ADC_BITS 10  'Number of bits in Adcin result
    DEFINE ADC_CLOCK 3  'ADC clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50
    pwm1            var portc.2
    '****                            Initialization
    't2con = %0000100    ;Fosc/4, no prescaler, no postscaler
    't1con = %00110001   'Enable Timer1 (16bit) /8 prescaller, int. Fosc/4 clock
                        '@ 20MHz times out every 104,86ms
    INT_LIST  macro    ; IntSource,        Label,       Type, ResetFlag?
    			INT_Handler   TMR0_INT,  _UpdateTimer,   PBP,  yes
    ;			INT_Handler   AD_INT,    _ADC_Sub,       PBP,  yes
    @ INT_ENABLE  TMR0_INT      ; enable Timer 1 interrupts
    ;@ INT_ENABLE  AD_INT        ; enable ADC Interrupt
    CLEAR
    loop1:
    goto loop1
    UpdateTimer:                        'This interrupt should happen every 25usec :(
        tmr0=213
        toggle portc.2
    @ INT_RETURN
    I miss something here but ... what?
    What happens if you make it an ASM interrupt instead of a PBP int.?
    Miami, Florida USA
    Ioannis,
    Try changing the PAUSE 100 to PAUSE 1. I read somewhere that using Pause 1 instead of a bigger number is better for the interrupts. Give it a try and let me know.
    Anonymous
    Thanks Dave.
    Hmm, almost half.
    PBP int., 207 reload, 101 usec
    ASM int., 207 reload, 41 usec
    But according to the calculations, 8MHz clock/4=2MHz or 0,5usec clock to TMR0. So a 207 reload should give about 24usec.
    Instead we get 41 or 101 usec, according to selected Interrupt.
    And this leads me to ask, why/when to use ASM instead of PBP as long as I use PBP in the ISR?
    @Robert. This is true for ON INTERRUPTS of the Compiler. Here I use DT_INTS14, so this is of no importance. Thanks anyway.
    OK, after some tweaking, and using ASM as TYPE (Don't know why yet), is getting correct results up to a reload value of around 180.
    The changes to get close are:
    @ INT_DISABLE TMR0_INT
        TMR0=TMR0+180
        toggle pwm1
    By adding the value,we have more precise control of the reload value.
    But not close to my target of 25usec
    Only guessing here, but I think Darrel ment the ASM type when there is ASM code in the ISR. I have noticed better accuracy with timers just by changing the type though.
    Now that I read this page again about the underscore, I may be doing something wrong. http://darreltaylor.com/DT_INTS-14/asm_ints.html
    Hmmm. Always something interesting..
    There are some shadows on the DT-INTs routines as there is no Manual. I am willing to help writing a manual document whenever Darrel can provide more insides.
    But for the moment the ASM idea seem to get closer to the target.
    Check the fine print at the bottom of the following
    http://darreltaylor.com/DT_INTS-14/kudos.html
    Fine print... There is always fine print....
    Hey Steve, Good to read you again!!!
    Hehe, you'll probably see me a bit more in 2011. Who knows?
    Steve : 2 points
    Dave : 1 point
    Simply Using MPSIM could have clearly shown what was going on.
    Interrupt duration always must be smaller than the period of the timer.
    Obvious, when it is told like this ...
    Sims sucks
    Hi Steve! What a surprise? Thanks for the tip.
    Yeah, I missed that one. Surely I am walking over the limit here.
