PM Asembler and Melab U2 Programmer Problems with PIC16F1939
Results 1 to 13 of 13
    Miami, Florida USA
    The new U2 programmer software version supports all the PIC16F193x. So, I was able to program my 16F1939 .
    What kind of interrrupt it is? Remember that ON INTERRUPT will jump in your ISR ONLY after finishing a x current job. So if you have, say PAUSE 5000, in your main loop, it may take up to 5 secondes to jump in the ISR (assuming your main loop is actually doing the PAUSE).
    The interrupts that I'm using are kind of complicated (at least for me ). To make the Capacitive Sensors to work a value needs to be read from TMR1L and TMR1H together. This would tell you if the sensor was touched or not. However, the interrupt overflow is determined by TMR0. This is the way is done in the Application Notes. The interrupt settings for a 16F727 look something like this and it works,
    OPTION_REG = %11000011       'Bit 2-0, 110= prescaler rate 1:16 (TMRO INTERRUPTS EVERY 1.024 mSec)
    T1CON = %11000101            'Timer1 initialization
    T1GCON = %11100001           'Timer1 gate init /Toggle Mode/TMR0 time base
    PIR1.7 = 0                   'Clear Gate Interrupt Flag. Timer1 gate is active (TMR1GIF BIT)
    PIE1.7 = 1                   'Disable the Timer1 Gate Acquisition complete interrupt (TMR1GIE BIT)
    TMR0 = 0			  'TMR0 overflows every (256-TMRO)*(Prescaler rate)(4*(1/16)uS)=1024uSec.
    ON INTERRUPT GOTO ISR
    INTCON = %10100000		'Enable Interrupts
    DISABLE			'Disable further interrupts
    ISR:
        T1CON.0 = 0                 'Stop/Clears Timer1 before reading TMR1
    "Read TMRL and TMRH"
        TMR1L = 0               'Reset Timer1
        TMR1H = 0
        T1CON.0 = 1             'Restart/Enable Timer1 (TMR1ON BIT)
        TMR0 = 0                'RESET TMR0 TO 0
        INTCON.2 = 0	          'Re-enable TMR0 interrupts. Bit 2, 0= clears overflow, 1= overflow ocurred
        RESUME				    'Return to main program
        ENABLE				    'Enable interrupts
    Anonymous
    Byte_Butcher was working on Capacitive Touch on a 727 with DT_INTS here ...
    http://www.picbasic.co.uk/forum/show...1611#post71611
    I'm not sure what needs to be changed for the 1939, but it's probably a good start.
    Miami, Florida USA
    Darrel,
    My program is working fine with the 16F727 and the 16F1939 as it is. But, I think it will run a lot smoother if I use the DT interrupts .
    The amount of time that the chip takes between ISRs is very critical for the CSM (Capacitive Sensing Module) to work properly. So, please excuse my next dumb question . Can I say that I have a much better control of the interrupt intervals using DT interrupts than using ON INTERRUPT? And why?
    Anonymous
    ON INTERRUPT will take care of the interrupt when it has time. A flag is set when the interrupt happens and is executed between instructions. If you have a long PAUSE the interrupt will not be serviced until the PAUSE is finished.
    ASM interrupts will take care of the interrupt immediately. Everything the chip is doing at the moment has to be saved then returned to. And the ISR is coded in ASM.
    Read the interrupt section in the back of the manual.
    DT's instant interrupts will make even a PBP type work like an ASM type.
    Miami, Florida USA
    Dave,
    Thank you. Your answer was really helpful. I have a lot of reading to do to understand better how these different interrupts work.
    Anonymous
