PM Asembler and Melab U2 Programmer Problems with PIC16F1939
Results 1 to 13 of 13
    Or it's working as design with MPASM, but have problem with PM, but... ya never know.
    Do yourself a big favor, isolate the problem, keep the ISR and a simple short and sweet main loop, see if the problem's still there.
    Usual Convention: Keep the ISR as short as possible.
    Get rid of PBP interrupt and use ASM one, or DT.
    Maybe not a bad idea to make sure you're using the latest MPASM version.
    Miami, Florida USA
    Bogdan,
    I have an old software version 4.23. In Melabs.com they have a free download for the latest Beta v4.32 software. I will install it and will post back with results.
    Mister_e,
    Yes, I know that I have to fix that problem with the interrupts to make the sensors work properly with MPASM. Now, I am using ON INTERRUPT GOTO ISR to handle the ISR. There are many lines of code that need to get done in the ISR routine. So, if I have many lines of PBP in the ISR routine, what method should I use?
    Should I go with something like this?
    @myint                  ; create myint label
       @ retfie  FAST       ; Return with 'auto restore' of WREG, STATUS and BSR
    Or, should I do something like this with DTs interrupts?
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INT_LIST  macro    ; IntSource,        Label,       Type, ResetFlag?
    			INT_Handler   TMR0_INT,  _MyInterrupt,   PBP,  yes
    @ INT_ENABLE  TMR0_INT      ; enable Timer 0 interrupts
    MyInterrupt:
    @ INT_RETURN
    Anonymous
    If you have PBP lines in your ISR, I'd say go for your second example.
    What kind of interrrupt it is? Remember that ON INTERRUPT will jump in your ISR ONLY after finishing a x current job. So if you have, say PAUSE 5000, in your main loop, it may take up to 5 secondes to jump in the ISR (assuming your main loop is actually doing the PAUSE). Maybe why your sensor doesn't work that good. Now why better on PM than MPASM, I don't know.
    Miami, Florida USA
    The new U2 programmer software version supports all the PIC16F193x. So, I was able to program my 16F1939 .
    The interrupts that I'm using are kind of complicated (at least for me ). To make the Capacitive Sensors to work a value needs to be read from TMR1L and TMR1H together. This would tell you if the sensor was touched or not. However, the interrupt overflow is determined by TMR0. This is the way is done in the Application Notes. The interrupt settings for a 16F727 look something like this and it works,
    OPTION_REG = %11000011       'Bit 2-0, 110= prescaler rate 1:16 (TMRO INTERRUPTS EVERY 1.024 mSec)
    T1CON = %11000101            'Timer1 initialization
    T1GCON = %11100001           'Timer1 gate init /Toggle Mode/TMR0 time base
    PIR1.7 = 0                   'Clear Gate Interrupt Flag. Timer1 gate is active (TMR1GIF BIT)
    PIE1.7 = 1                   'Disable the Timer1 Gate Acquisition complete interrupt (TMR1GIE BIT)
    TMR0 = 0			  'TMR0 overflows every (256-TMRO)*(Prescaler rate)(4*(1/16)uS)=1024uSec.
    INTCON = %10100000		'Enable Interrupts
    DISABLE			'Disable further interrupts
    ISR:
        T1CON.0 = 0                 'Stop/Clears Timer1 before reading TMR1
    "Read TMRL and TMRH"
        TMR1L = 0               'Reset Timer1
        TMR1H = 0
        T1CON.0 = 1             'Restart/Enable Timer1 (TMR1ON BIT)
        TMR0 = 0                'RESET TMR0 TO 0
        INTCON.2 = 0	          'Re-enable TMR0 interrupts. Bit 2, 0= clears overflow, 1= overflow ocurred
        RESUME				    'Return to main program
        ENABLE				    'Enable interrupts
    Anonymous
    Byte_Butcher was working on Capacitive Touch on a 727 with DT_INTS here ...
    http://www.picbasic.co.uk/forum/show...1611#post71611
    I'm not sure what needs to be changed for the 1939, but it's probably a good start.
    Miami, Florida USA
    Darrel,
    My program is working fine with the 16F727 and the 16F1939 as it is. But, I think it will run a lot smoother if I use the DT interrupts .
    The amount of time that the chip takes between ISRs is very critical for the CSM (Capacitive Sensing Module) to work properly. So, please excuse my next dumb question . Can I say that I have a much better control of the interrupt intervals using DT interrupts than using ON INTERRUPT? And why?
    Anonymous
    ON INTERRUPT will take care of the interrupt when it has time. A flag is set when the interrupt happens and is executed between instructions. If you have a long PAUSE the interrupt will not be serviced until the PAUSE is finished.
    ASM interrupts will take care of the interrupt immediately. Everything the chip is doing at the moment has to be saved then returned to. And the ISR is coded in ASM.
    Read the interrupt section in the back of the manual.
    DT's instant interrupts will make even a PBP type work like an ASM type.
