"symbol not previously defined" on 16F1933 - fuse issue i think
Results 1 to 3 of 3
Threaded View
    Default "symbol not previously defined" on 16F1933 - fuse issue i think
    ok, i write 3 lines of code and already i get an error...
    ERROR[113] blah.asm 328: Symbol not previously defined (_CONFIG1)
    ERROR[126] blah.asm 328: Argument out of range (not valid config register address)
    ERROR[113] blah.asm 334: Symbol not previously defined (_CONFIG2)
    ERROR[126] blah.asm 334: Argument out of range (not valid config register address)
    and my code...
    Define  OSC				32					' Set clock speed
    @ __config __CONFIG1, _FOSC_INTOSC & _WDTE_NSLEEP & _PWRTE_ON & _MCLRE_OFF & _BOREN_ON & _IESO_OFF & _FCMEN_ON
    @ __config __CONFIG2, _VCAPEN_OFF & _PLLEN_ON & _STVREN_ON & _BORV_25 & _LVP_OFF
    In P16F1933.INC in the MPASM SUITE folder it says...
    ;       Configuration Bits
    ;   NAME            Address
    ;   CONFIG1           8007h
    ;   CONFIG2           8008h
    ; The following is an assignment of address values for all of the
    ; configuration registers for the purpose of table reads
    _CONFIG1         EQU  H'8007'
    _CONFIG2         EQU  H'8008'
    ok, i have no idea...
    Can someone shed some light please. Thanks
    :additional
    I checked the datasheet, the config word addresses are correct...
