Can't @sleep
Results 1 to 4 of 4
Thread: Can't @sleep
    Alabama,USA
    Default Can't @sleep
    I thought I had this figured out, famous last words! Returning to a project after being side tracked for six months I find that the @sleep command was never working. 12F683 set up with GP2 ext interrupt to wake from sleep. Test code for @sleep instruction uses LED to monitor sleep state. MCLR is set to off. There is a line in the data sheet that says that if Watchdog Timer is enabled, MCLR pin must be at a logic high, I am turning off WDT before @sleep. I can’t find the problem. Comments please…
    @ DEVICE PIC12F683,MCLR_OFF,WDT_ON,BOD_OFF
    @ DEVICE PWRT_ON,FCMEN_OFF,IESO_OFF,PROTECT_OFF
    OSCCON=%1110000
    Define OSC 8
         VRCON  =  0
         ADCON0 =  0
         OPTION_REG = %01000000 ;rising edge interrupt
         ANSEL  =  0    		;digital all
         CMCON0 =  7
         INTCON =  %10010000    ;GlE set, INTE set, INTF clr
         GPIO   =  0
         TRISIO =  %00001100	;GPIO.2 input for external interrupt
    ;-------- Variables & Constants ------------------------------------------------
          Avar    VAR BYTE        ;general variable
    ;     Inerrupt on GPIO.2
          Blink   var GPIO.4
          TX      var GPIO.5
    ;-------- Program --------------------------------------------------------------
        for Avar=1 to 5
        HIGH    blink
        pause   40
        low     blink
        pause   100
        next Avar
    Downtime:
        WDTCON=0     ;Watchdog timmer off
    @sleep           ;Sleep in low power state until interrupted
    @nop
        INTCON.4 = 0     ;clear external interrupt flag bit
        Serout2 tx, 84, [" We have a wake up from sleep or it never went to sleep",13,10,13,10]
        for Avar=1 to 5
        HIGH    blink
        pause   50
        low     blink
        pause   2000
        next Avar
    There should be white space (space or tab) between the @ and sleep. Same with nop.
    @  sleep
    Alabama,USA
    Default WDT and software control
    I found a statement in the data sheet that addresses WDT under software control. I have now turned off WDT in the config to use SWDTEN bit properly. Still no luck. No rest for the weary.
    Alabama,USA
    Default It's the little things that get you every time!
    Thanks Darrel,
    Space did the trick. I'm up and running.
