I've registered and awaiting confirmation so I can post the questions. I'm sure it is something simple as I'm able to compile the code, upload it and the pic runs (modified the example to flash a LED on port B a few times as it went through the code. I also get a solid LED indicating connectivity and random flashes on the activity LED. I've tried 18F4520 with 4MHz, 10Mhz, 12Mhz xtals, and various OSC settings (HS-PPL etc) in the programmer - Tried it with pull ups and pull downs on portc.0, 1 and 2. Thing is that if I re-load my thermostat code into an 18F4580 and connect the RTC on port C it runs sweet. Turn off, remove the RTC module, plug in the serial Ethernet board and then burn the demo code (modified to contain my network IP dns etc setting) I get the same issue described above.
Tried various examples from their website and still no joy. There is only one jumper on the ethernet board which selects the voltage - in my case 5v as that's the voltage of the supply and logic lines - this (according to the basic manual and schematic) enables the 3.3 regulator and routes the logic through the level shifter
If anyone has some PBP code to try to confirm the SPI interface works between the PIC and the ethernet board - sorta flash LED if comms established - it would help put my mind at rest that there is no fault with the board
