I gave it a try, could not get it to work correctly
Two 10k resistors as a voltage divider giving a reading of 127 with the serial output on a different pin.
When the serial output is placed on the ADC pin the ADC value drops to 16. The ADC value will change if the divider is changed and the serial still works, just getting incorrect values.
Test code:
Code:' ADC TEST FOR CHANNEL 2 WITH SERIAL2 OUT '<FL_PIC12F675>' '<FL_PBPW>' DEFINE OSC 4 @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF CMCON=7 ' ANSEL=%00000100 ' TRISIO = %000100 RESULT VAR BYTE 'A/D CONVERSION RESULT STORAGE BYTE START: 'A HEART BEAT GPIO = %010000:PAUSE 500:GPIO = %000000:PAUSE 500 SEROUT2 GPIO.2, 16780, ["RESULT ",DEC RESULT,$a,$d] PAUSE 250 GOSUB ADC_2 'STARTS THE READING OF ADC CHANNEL 2 GOTO START ADC_2: 'READ AN2 GPIO2 PAUSE 100 ANSEL=%00000100 TRISIO = %000100 GPIO = %000100 ADCON0 = %00001001 'TURNS ADC ON GOSUB READ_AD RESULT = ADRESH 'PLACES THE ADC VALUE INTO VAR ANSEL=%00000000 TRISIO = %000000 RETURN READ_AD: 'DOES THE ADC CONVERSION PAUSE 50 ADCON0.1=1 WHILE ADCON0.1=1:WEND RETURN
