A new MPLAB IDE
Results 1 to 40 of 56
Thread: A new MPLAB IDE
    Default Re: A new MPLAB IDE
    I don't know what either one is anyways.
    True source is being able to look at the assembler-generated code maybe?
    Code folding is where the IDE/Editor "folds away" the code when you don't need to see it. For example, it hides everything between IF and ENDIF statements, then you can "expand/hide" the section by toggling a little a button right next to the start of the section. See the attached screenshot.
    rmteo gave a good explanation pof source level debugging. MCSP provides it, sort of, but the way its done with MCSP has several drawbacks. It's possible to do tight now with MPLAB 8.xx (and I suppose x).
    What's this I hear about a new IDE? Are there a new version of MCS on its way or is something completely different? Speak up! ;-)
    You haven't checked WikiLeak?!?
    It's something in progress since years and who's having reach another level, and still in progress. Can't say much... just be patient.
    If someone really pays me a lot, I can give a name
    Yeah me too... some NDA signed as well
    May 2007
    Hopefully this new, super-secret vaporware (oops vectorware) works better than this http://www.microchip.com/forums/tm.a...mpage=1#576676
    Hi - I have just downloaded and tested Beta 6 after not using MPLAB X for some time due to its useability.
    I still find that the product is still not really useable. It is very slow in debugging and stepping, does not allow debugging of interrupt service routines and is pretty unstable.
    I personally do not feel that this platform will ever be a replacement for the present MPLAB IDE due to the inherent problems with NetBeans. If A new editor was slotted into MPLAB IDE 8 it would probably be a far better route than MPLAB X.
