HPWM at very low frequency
Results 1 to 7 of 7
    Sep 2006
    Default HPWM at very low frequency
    The very short program works but the frequency output is extremely variable from 500Hz to 2Khz. The program should max at 512Hz..
    Also the output is very noisy, any recommendation on the output ? extra capacitor ?
    '// 555 simulator using PIC16F88
    '// Variable frequency, fixed Dutycycle
    '// Define section //
    INCLUDE "modedefs.bas"
    OSCCON = %01110000 '8 Mhz
    DEFINE OSC 8
    ANSEL = 0
    CMCON = 7
    DEFINE CCP1_REG PORTB 'Define output port of pulses out
    DEFINE CCP1_BIT 0 'Define output port of pulses out
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_SAMPLEUS 50 ' Set sampling time in uSec
    TRISA = %11111111 ' Set PORTA to all input
    TRISB = %00000000 ' Set PORTB to all output
    voltage_check var word
    Frequency var word
    Mainloop:
    ADCON0.2 = 1 'Start Conversion max 1024
    ADCIN 3, voltage_check 'analog pin 1 get the 10 bit result  Check the battery voltage on pin PORTA.3
    Frequency = voltage_check /2  'max 512Hz
    HPWM 1,126,Frequency
    goto Mainloop
    This has the ADC turned off.
    ANSEL = 0
    Try
    ANSEL = %00001000
    Hi, Dave
    did you notice the generator will only output 489 to 512 Hz ???
    ... RTFM ???
    Yes Ken, you should read your manual, HPWM section ( or the Pic Datasheet ! )
    Yup, and the OP said it was going from 500 to... So that part sounds about right. Does he want something slower?
    Sep 2006
    Argrr, ya, I read the text but I skipped the table, But I need lower frequency then 489Hz, Actually I need between 10 to 300Hz, I think I am better off with what I am using now, a 555 timer.
    K
    Quote Originally Posted by lerameur View Post
    K
    you can use a PIC, but with " soft " PWM generation ...
    Also have a look to what the CCP module can do for you ... more than generating PWM.
    in Compare mode, for example ... you easily can reach 2Hz ...
    a Timer1 Overflow interrupt also will work fine ...
