Yup, that's part of that "strategically" idea.
And now you will appreciate the idea of "Event Driven" software, instead of GOSUB somewhere then return when it's finished, whenever that is.
With event driven, everything keeps running, even if you're moving through menu's on an LCD.
Keep in mind that if your light bulb spark is causing a false button press and it's going off into one of those routines ... the WDT won't help unless that routine times out eventually because now you've added CLEARWDT's to it.
