A quick question.....
Results 1 to 2 of 2
    Nov 2009
    London
    Default A quick question.....
    Is it correct to do the following:
    abc var word[2]
    abc=0
    loop:
    abc=abc+1
    if abc=80000 then
    high LED
    abc=0
    goto loop
    No, that's not OK. If you have PBP250 or above you can use longs (switch compiler to PBPL) and do:
    abc VAR LONG   'Declare abc as a 32bit variable
    If you don't have PBPL you can either use N-bit-Math (Darrels math routines) or do something like (not tested)
    abc var WORD
    abc_ten_thousands VAR WORD
    MainLoop:
     abc = abc + 1
      If abc = 10000 then
       abc_ten_thousands = abc_ten_thousands + 1
       abc = 0
      Endif
      If abc ten_thousands = 80 then
       High LED
       abc = 0
       abc_ten_thousands = 0
      EndIf
    Goto MainLoop
    Also, note that the word Loop is a reseved word in newer versions of PBP.
