I think if you just send the value without any formatting, it's in raw format.Is the PIC capable of sending RAW binary data??
I.E. X = 10 : HSEROUT [X].
You can send whatever value's in X directly to the USART TXREG like this,
and I'm fairly sure the PIC doesn't automatically convert bytes placed in
TXREG to ASCII;
I don't have MATLAB to test this, but I can't see why it wouldn't work. I getCode:SPBRG = 64 ' 19200 bps @20MHz RCSTA = $90 ' Serial port enable TXSTA = $24 ' Transmit enable, BRGH = 1 for high-speed X VAR BYTE TRISC.6=0 MAIN: FOR X = 0 to 255 GOSUB ENCODE PAUSE 50 NEXT X X = $0D ' Carriage return GOSUB ENCODE X = $0A ' Line feed GOSUB ENCODE PAUSE 100 GOTO Main ENCODE: ASM movf _X, W ; Load X into W reg btfss PIR1,4 ; Wait for TXREG to be empty after last byte goto $-1 ; Not empty, wait movwf TXREG ; Empty, so send next byte ENDASM RETURN
the same results from either method with a standard terminal program.
