No it doesn't necessarily have to be in assembler, but it's a lot faster if it is. If you prefer to use BASIC then look into using DT_INTs.
Yes - you can have every interrupt that's available enabled. You just need to check in the interrupt handler to see which one triggered the interrupt.
